1999 Cooper Sportspack @ Mill Road Garage
307 replies to this topic
#196 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 February 2017 - 07:06 PM
Hi all.
I have now welded on the scuttle panel
I made up and fitted a new closing panel as the old one was a bit thin
Then started to align the new nose panels
Overall pretty good but the wing to bonnet gap on the passenger side needs some work as the fit is pretty terrible.
It turned out to be the new scuttle panel. It was the wrong profile causing the wing to not be able to move over round it far enough on the seam.
After sorting that out i removed the front as a complete unit
And welded the wings to the front panel
And then fitted it back to the car
Once everything was lined up, i began by welding the drivers side wing
I have began the welding the other side which needs to be finished tomorrow and then i shall fit the A panels which means doors back on and then drop out the subframe to complete the welding on the front panel to inner wing areas.
Thanks for looking
Ben
#197 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 16 February 2017 - 08:14 PM
Nice work as usual, Ben seems we have a lot of the same equipment I used to have
one of those Snap-On bonnet props!!! unfortunately sold it along with most of my
other tools when I retired and went to live the dream in Cyprus ;D
Then came back and started restoring minis as a hobby.
#198 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 February 2017 - 08:31 PM
It's a useful piece of kit even though it's worn out and slightly bent  >_<
I sold all of my stuff when i came out of panel beating and am now having to re-buy it all now i'm back at it.
Still, it is a good chance to get better stuff than i could afford before.
Ben
#199 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 16 February 2017 - 09:12 PM
HaHa my bonnet prop was a bit the same! was more used to jam brake pedals
down when replacing brake pipes.
I was fortunate to manage to get some of my panel beating tools back from the
guy that i  sold them to they were pretty good quality Snap-On hammers ect and
a couple of Gedore dollys that I had since I was a first year apprentice , and I don't
what to buy any more as my current restoration will be the last :goaway: now in my 70th
year finding it quite hard on my bodywork!!!!!!!
#200 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 February 2017 - 09:24 PM
I'm finding it hard to avoid buying more and more
Our painter has moved on so i'm on my own in the bodyshop now which means I have now had to buy spraying equipment so i can take over that too.
A decent spray gun isn't cheap but you can't do a nice job without it.
I have got a long way until retirement so i need stuff that will last
I think when i sold my tools, i only kept my hammers, dollys and other beating gear and a few hand tools so needed to buy a fair amount when i came back to it.
I don't think i will ever stop needing to buy tools, there is always something you think of just when you need it!
#201 jamesquintin
jamesquintin
  • 1,025 posts
Posted 17 February 2017 - 03:22 PM
You got yourself a spot welder then...?
Q
#202 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 February 2017 - 06:04 PM
Q
Yes.
I finally managed to find a proper one that wasn't thousands of pounds and i didn't want to use or trust anything other than a proper one which is why it's taken until now to get one
#203 jamesquintin
jamesquintin
  • 1,025 posts
Posted 17 February 2017 - 07:51 PM
nice, looks like factory welds. What one was it?
Q
#204 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 February 2017 - 08:20 PM
Q
Its an Elektron multispot M80
#205 panky
panky
  • 1,853 posts
Posted 17 February 2017 - 08:54 PM
That's brilliant, I wont show you any pics of my plastering, sorry, welding :D
#206 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 February 2017 - 09:12 PM
There should have been an update tonight but i left the Camera at home last night so couldn't take any pictures.
Basically, the front end is now fully welded on and i have removed the subframe.
I have put the doors back on ready for fitting the A panels which i shall hopefully do Monday.
Other than that, it is ready to prep for paint.
Ben
#207 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 February 2017 - 08:24 PM
Hi all.
I'm a little behind at the moment after catching up with all of my day to day bodyshop jobs but at last, i had chance to work on the Cooper this afternoon.
No jobs are in tomorrow so ill be able to get all day on it which should see it prepped and hopefully in primer.
So to catch up, both Apex panels are now fitted
I have finished all of the last bits of welding and finishing ready for a smidge of stopper here and there to smooth things out.
And then i started the irreversible task of trimming the wheel arches ready for the sportspack arches
First up, some tape is stuck on
And then the templates are carefully cut out and pieced together
Then the cut line is transferred onto the tape
And then trimmed with the air saw
I have prepped the new lip/stiffener and trial fitted it. It doesn't fit too well as they are formed to a completely different profile to the wings but i shall overcome this with some careful trimming to improve things to make it a nice tidy job despite the fact it will never be seen under the arch..
More tomorrow
Ben
#208 skoughi
skoughi
  • 1,200 posts
  • Local Club: Shetland classic car club
Posted 21 February 2017 - 10:25 PM
When I trimmed back the arches on my Clubman I marked out the line where the new arch was to be then marked a second line 10mm inside this, I cut to this line then formed the lip by slowly bending it out with large vice grips then finished off with hammer and dolly. At least doing it that way it saved a lot of welding and to my surprise it actually turned out ok!
#209 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 February 2017 - 07:05 PM
Today i finished up the last of the panel work.
First up, I welded in the arch lip/stiffener on the o/s
And then marked out for the mounting holes.
First up, I stuck tape in line with the stud holes and marked the centre of the hole on the tape
Then transferred the markings onto the wing
Before drilling the holes
And then test fitting the arch
All is well.
Then i started the process on the other side
I test fitted the bumper to check that the arches do not foul the bumper ends
So that's that job sorted.
So that's the panel work complete
So onto the prep.
I sanded the e-coat to key it up and took it off in places where there looked to be imperfections under the coating
I finished up today by doing a small amount of filler work to smooth things up in places and apart from a small amount of cleaning back to do on the bulkhead, it's ready for primer.
Ben
#210 nicnoo
nicnoo
  • Just Joined
  • 212 posts
  • Local Club: south warwickshire minis
Posted 23 February 2017 - 12:58 PM
Love the trick with taking the front end off and turning it upside down. will have to remember that one when doing mine.
Excellent work as usual
    Bing (3)
