1999 Cooper Sportspack @ Mill Road Garage
307 replies to this topic
#136 jamesquintin
jamesquintin
  • 1,025 posts
Posted 17 December 2015 - 08:29 PM
ah ok cool. I've seen a few gaps here and there on various build threads and always wondered how they got closed up
​Cheers
JQ
#137 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 December 2015 - 08:31 PM
​Cheers
JQ
Yeah, no worries.
Nothing on a Mini fits that great really so it's just a case of making a few changes as you go along to improve the quality.
I would rather have small gaps plugged up with weld than relying on sealer to do the job
#138 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 December 2015 - 09:59 PM
The discussion about the gaps prompted me to check my own Mini.
I haven't welded mine yet. I must remember to...
#139 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 18 December 2015 - 11:15 AM
Rightly or wrongly I'm yet to find out when I did mine with the same issue instead of fitting the closers I replaced the step part with a longer piece that goes to the quarter and welded it directly to the quarter so the little crescent piece in front of the wheel is only single skin. If that makes sense
#140 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 December 2015 - 08:02 PM
I know what you mean :-)
#141 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 December 2015 - 06:25 PM
Bumper update time.
have been working on the Cooper this weekend in an effort to get it ready for its MOT tomorrow afternoon.
With the welding finished it was time to start the prep.
here are the completed Flitch repairs
And i finished up the grinding and dressing on the rear bulkhead to arch tub joins
And a scrape of filler here and there
And then masked up for some primer
Obviously those were taken prior to wiping down and de-greasing
And then once the primer had been applied and flatted, it was time to seal up and then some colour
And done..
Once the paint was cured, The sills, boot floor flitch bottoms and arch tubs were stonechipped
It looks very grey in the photos. I think they are over exposed because they are black in the flesh.
Then the new radius arms were painted and baked in the booth
And assembled onto the new subframe with new seals, trust washers and hardware
As well as that, new trunnions and bushings were fitted, billet handbrake quadrants and all new brake pipes and flexi hoses
Then the radius arms were secured to the frame with cable ties to stop them dropping, the anti drum pads were stuck onto the top of the frame and it was ready to fit.
i also applied plenty of wax into the box sections of the frame, in and around everywhere and on the top of the frame.
before the frame went in, i waxed the boot floor and heelboard.
And then the frame went in
Then the shocks were fitted, the wheel cylinders were hooked up with more new brake pipes and the shoes installed/
Then new bearings were fitted into new hubs and they were bolted on too
Then the handbrake cable was run and the drums fitted and we have back wheels!
Then working under the car, the brake pipe was connected and the fuel lines were run and connected with a new filter and bracket
Then i laid some new anti drum pad to the floor and ran the wiring loom
anti drum was laid the other side too and then once the SRS module was fitted and wired up, the carpet was re fitted. I also filled the crossmember with wax prior to laying the carpet
I then cleaned the inside of the sill trims and filled the channel with wax and then pushed them on
And that was it for the weekend.
Tomorrow, ill finish the interior, fit the boot out with the tank etc after fitting the rear sportspack arches then on with the bootlid, bumper and lamps.
Just before the end of play, i painted the rear valance again after the stonechip.
I like to apply stonechip after paint so you have the protection of the paint beneath instead of just primer like rover.
It should be ready in time.
Ben
#142 wingnut
wingnut
  • 468 posts
Posted 20 December 2015 - 06:42 PM
Great work again Ben
#143 carthorse
carthorse
  • 257 posts
Posted 20 December 2015 - 06:56 PM
That's a good weekends work - hope the customer appreciate's it and you get some overtime pay in time for crimbo!
#144 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 December 2015 - 06:58 PM
No overtime sadly.
I'm actually doing it purely so it can be finished in time for Christmas.
we pack up Wednesday so if the Mini is collected Tuesday, ill have Wednesday off
#145 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 20 December 2015 - 07:27 PM
Fantastic work Ben. It looks super!
Can't wait to watch your progress on the other projects you have lined up :D
#146 Carlos W
Carlos W
  • 10,115 posts
Posted 20 December 2015 - 07:30 PM
Looking superb mate
#147 jamesquintin
jamesquintin
  • 1,025 posts
why no final red coat...?
#148 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 December 2015 - 07:35 PM
On the sills?
If so, it's gone back to the scheme when it came in.
#149 markyB
markyB
  • 93 posts
  • Local Club: Bomber County Minis
Posted 20 December 2015 - 10:47 PM
An epic weekends work ! Sir I applaud you
#150 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 21 December 2015 - 06:27 AM
Some nice fast work there those repairs look ace :)
    Bing (1)
