1999 Cooper Sportspack @ Mill Road Garage
304 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 November 2015 - 06:29 PM
Hello All.
This is to be a thread documenting some body repair and MOT work we are undertaking at Mill road garage on the Isle of Wight on behalf of a fellow TMF'er.
We had the car recovered to our workshop this morning for inspection before work commences.
Initially we quoted for work to the sills as it currently has cover sills fitted but further inspection was required as well as putting it through an MOT to see if and what else needed doing as the car has been off the road for 2 years.
Here is the car as it arrived just prior to performing the MOT test.
Apologies for the blurry photo but i didn't realise it was until i uploaded it to the computer :(
So after inspection of the car, we have found some more corrosion to the rear arch tubs, the rear valance and closing panels which unfortunately contributed to the MOT fail.
It's a lovely little Mini and certainly attracted a lot of attention from staff in neighboring units and will soon be returning to the road.
Work has started on stripping out the car so it is well under way.
I will update this daily as progress is made.
More tomorrow.
Ben
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 23 November 2015 - 08:42 PM
I'm sure it'll be excellent mate
#3 toplessmini
toplessmini
  • 492 posts
  • Local Club: none on the island....
Posted 23 November 2015 - 09:00 PM
I just wish I could have washed it before it was taken away, bloody clutch........
#4 James_eaton_thewholething
  • 1,063 posts
Posted 23 November 2015 - 09:02 PM
Looking forward to seeing updates
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 November 2015 - 09:23 PM
No worries, It will be washed and polished before it goes home.
And the clutch is now working. The arm was stuck so the clutch was stuck on. we freed it up but it will require cleaning up properly before It goes anywhere. I will sort that for you though.
Shame we freed it up after the MOT. You should have seen us trying to push it on and off of the rollers :lol:
#6 Steve220
Steve220
  • 5,033 posts
  • Local Club: BMC
Posted 23 November 2015 - 09:45 PM
Hopefully the remnance under the oversills won't be too horrific, the car overall looks in great condition! (Despite the shakey pic!)
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 November 2015 - 09:56 PM
I know exactly what it will be needing as i stripped it out this afternoon. :-)
Ill pop some pictures up tomorrow
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 November 2015 - 07:09 PM
Work recommenced today on the Cooper.
The First job was to carefully remove the Sports Pack arches so the front wheels were removed in turn to access the fixings.
As you can see, i also removed the rear ones after stripping out the interior.
Then the bootlid, bumper, battery, fog light and fuel tank was removed
And then the wiring harness was passed through the inside of the car and bundled up out of the way leaving the inside nicely stripped out
Next up was removing the rear subframe so the exhaust was removed, the brake lines and handbrake cable were disconnected and the subframe mount bolts were cracked off.
Of course, the wheels were removed first.
A bit of a struggle with the seized bolts later and the frame was ready to come down.
Using a combination of the ramp jack and a couple of axle stands, the frame was free of the car.
And out
This subframe is heavily corroded as you can see in the following photos.
But a new one has been provided by the customer along with all new parts to fit to it.
So with the strip out completed, we can start to look at the work that is going to be needed.
This car has had cover sills fitted in the past
They are in places, fitted over the existing sills, and inside the companion bins, sections of the inner sill have been cut away and not replaced with any steel at all.
Besides this, cover inner sills have been fitted and just seam welded around the edges to the seat cross members. Not a particularly tidy job but i suppose it served it's purpose in the past.
So new full inner and outer sills will be fitted. I will also fabricate new seat crossmember ends to replace the old ones.
Next we have the rear arch tubs which are too far gone to repair so a pair of new ones will be fitted.
One side
And the other
Then onto the rear end, the boot floor will be repaired as well as a new rear valance and closing panels
I shall also be repairing the lower rear panel to sort out some heavy corrosion on the bumper lip.
The heelboard doesn't look to bad and seems solid. There will be some repairs needed on the ends but overall pretty good
And now to start the cutting.
first to go was the rear valance.
I have also cut out portions of the rear panel bumper lip to replace.
The boot floor will need some repairs as it has been repaired in the past using wire mesh and body filler
The entire bumper lip is crusty so It may need more repairs than i thought. I will also be fitting a full width repair panel on the back of the boot floor.
So here we are for today.
Tomorrow will see the release of the old crusty rear arch tubs as well as the valance closers and the repairs to the bootfloor and rear panel will begin.
Ben
#9 Steve220
Steve220
  • 5,033 posts
  • Local Club: BMC
Posted 24 November 2015 - 07:32 PM
Christ, fair bit of rust! Is that a new genuine sports pack rear subframe?
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 24 November 2015 - 07:34 PM
Not bad for a day's work mate
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 November 2015 - 07:47 PM
It looks like it to me.
The customer ordered it and supplied it to us.
Ben
#12 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 November 2015 - 07:48 PM
That wasn't all day mate. I spent quite a bit of time with paperwork and on the phone ordering parts.
#13 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 24 November 2015 - 07:53 PM
Interesting stuff, still in pretty good shape for a Sports Pack though. Looks like you have got to it in time to turn it around. Keep the updates coming
#14 toplessmini
toplessmini
  • 492 posts
Posted 24 November 2015 - 08:26 PM
Yep.....
#15 Steve220
Steve220
  • 5,033 posts
  • Local Club: BMC
Posted 24 November 2015 - 08:33 PM
Yep.....
Out of curiosity, where did you manage to source one? I've struggled to find anyone with them in stock.
    Bing (1)
