Beam Axles...
63 replies to this topic
#46 Ethel
  • 25,909 posts
Posted 10 October 2009 - 11:22 PM
The springs on the purpose made coilovers for Minis are rising rate but something in the region of 80-100lb springs would be about right. Crash resistance is worth thinking about, but there's no reason why the rear subframe should be thought of as the best protection possible.
#47 little stu
little stu
  • 19 posts
Posted 11 October 2009 - 06:59 AM
you can just use the heelboard section from the subframe and fit coil overs saving lots of money and weight. there was a thread on this before but cant find it now......
#48 MRA
MRA
  • 7,607 posts
Posted 11 October 2009 - 08:33 AM
You have to do a lot of work to make this safe.......... people have done it over the years and found that the subframe suddenly fails under heavy cornering forces.........
For information....
A beam frame will do little to increase your handling, however a beam axle will do amazing things.... over the years I have made several beam axles and the one thing that sticks in my mind is the awesome cornering that a good beam axle will give you.... once set up correctly of course.... the only disadvantage is boot space can be a little smaller.... :thumbsup:
Turn-in on cornering is something that has to be witnessed, but you will NOT get this with a beam frame.
#49 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 October 2009 - 09:52 AM
Does anyone currently make proper beam axles? I know I read about an Aldon one in one of Vizard's bibles. But I don't think that was a 'production' item.
#50 jameswildcooper
jameswildcooper
  • 1,991 posts
Posted 11 October 2009 - 12:17 PM
i have one for sale if anyone is interested im converting to rear disc conversion so not bothering with the one i have.
#51 MRA
MRA
  • 7,607 posts
Posted 11 October 2009 - 01:12 PM
I will have one ready for early next year, just going through the design phase.... will need some testing done on them first, however it is based on Beam axles that we have made in the past, and the idea is that it comes in a complete kit.... including modified floor pan and turret tops :thumbsup:
#52 JonBetts
JonBetts
  • 298 posts
Posted 12 October 2009 - 08:29 AM
Been looking at the MK1 Fiesta rear beam axle, nice compact unit, would need narrowing but it does look like it would be relativly easy to fit, has anyone tried this or anything similar?
#53 ludsonline
ludsonline
  • 129 posts
Posted 16 December 2009 - 05:47 PM
I did look at a Fiesta one as well Jon. The thing that put me off was the lump in it. I am currently building a beam axle setup. It will have some neat little tricks as well. Watch this space.
#54 Italianjoblofty
Italianjoblofty
  • 225 posts
Posted 03 May 2010 - 02:06 PM
Hi just wondering if you are any closer to making the kit you have mentioned above?
Edited by Italianjoblofty, 03 May 2010 - 02:09 PM.
#55 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 03 May 2010 - 04:03 PM
i had a beam frame on my last track day mini, with gaz offset coilovers, and standard cast radius arms with the knuckle point cut off, and i thought it was brilliant on the road and track.
the weight difference is minimal though as a bare rear subframe weighs little anyway, and the box section used in a beam frame is quite heavy, however all the weight in the beam frame is further forward in the car, as its basically right up against the heal board.
on my new project i will be doing coilovers, and a beam, but will probably make my own this time as there is nothing to them, but hopefully it will be an extruded alloy one this time.
the only heavy thing then will be the rear arms, but i do have a jig made up to make some tubular ones.
#56 MRA
MRA
  • 7,607 posts
Posted 03 May 2010 - 04:08 PM
I will have one ready for early next year, just going through the design phase.... will need some testing done on them first, however it is based on Beam axles that we have made in the past, and the idea is that it comes in a complete kit.... including modified floor pan and turret tops :tumble:
The beam axle, is still being worked on......... I expect 1 to 2 monthes. It is NOT a beam frame, the two items are completely different, this does mean that most or all of your boot will be lost :thumbsup:
#57 oOominioOo
oOominioOo
    Starting My Mini Up
  • 1 posts
Posted 16 October 2014 - 03:07 PM
hi i have been reading this post about useing mk5 escort  beam axle.. biy i cant see the images that are posted, or how to do it is there another post to show this,, as i would realy like to do this mod on my mini thanks . jason ..
#58 1330RG
1330RG
  • Just Joined
  • 219 posts
Posted 16 October 2014 - 05:58 PM
Why would you want a beam axle? Independant rear is far better for handling, surley a rear beam set up is a step down
#59 Cooperman
  • 23,273 posts
Posted 16 October 2014 - 09:23 PM
The rear beam is really a racing modification for smooth tracks.
It is difficult to beat the as-designed rear sub-frame as it holds everything together at the back and the dynamic loads go in to the car as intended.
When introduced, and ever since, the beauty of the Mini has been its independent suspension all round which was such a big advantage over its original rivals like the Ford Anglia which had a solid beam axle and leaf springs at the rear.
I've never understood why anyone would want a beam axle for a road car, but fully understand why they would want one for racing.
#60 Tupers
Tupers
  • 4,142 posts
Posted 16 October 2014 - 09:35 PM
My uncle has a proper beam axle in the back of his hillclimb car. As Cooperman says they can be very good for motorsport but not really much use on the road.
Attached File  19808_139011719599836_2047528107_n.jpg   47.55K   29 downloads
