Beam Axles...
Posted 13 August 2006 - 04:41 PM
I had done a seach and couldn't really find what I was after...
All I know about beam axles is that they improve handling no end... and that I have to cut my boot out...
I wsa wondering, does anyone have any detailed pics of a beam axle fitted? and how does it fit...
I am tempted to do this, just to save weight!! but if its going to be a costly, time watsing process I won't bother.
Posted 13 August 2006 - 06:23 PM
Posted 13 August 2006 - 07:18 PM
But if you want a proper rear beam axle, i think Allspeed engineering do a 5 link one, or something like that. But i think you have to do major mods to the boot floor and heel board panel, dont quote me on that though.
Posted 13 August 2006 - 07:59 PM
Posted 13 August 2006 - 08:22 PM
I have heard one beam that one company make is a bit weak... whos is it?
Posted 13 August 2006 - 08:36 PM
Posted 13 August 2006 - 08:39 PM
also, it's not a beam axle, it's a beam subframe.... very subtle but important differences as higlighted above...
Posted 13 August 2006 - 08:42 PM
So who else does Beam"subframes"?
Posted 19 October 2008 - 04:41 PM
Edited by mozzo1, 19 October 2008 - 05:14 PM.
Posted 19 October 2008 - 06:51 PM
The only alteration I had to do was to cut the knuckles off the radious arms where the trumpets would normally fit in to
Posted 22 October 2008 - 06:01 PM
do you mean a proper beam axle (as in the same on an mk5 escort etc) or the aftermarket one that does away with the cones? if you talking the latter of the two i have fitted one, found it to be quite easy. i have yet to test it on the road but it is a hell of alot lighter! heres some pics. if not disregard whit i just said
hi steve did you have to cut anything to get your coil overs on as i put my standard ones on just as a moc up and there quite close to body and obviously coilovers will have a spring to fit in there as well
Posted 22 October 2008 - 06:09 PM
Heres a pic of an FRA alloy one on mine
am i right in thinking that your rear beam is just a u profil on its side with some brackets made for the radius arms and a couple of bolts through the heal board ???? it looks like that from what i can see in the picture of yours
is there a homepage or some better pics somewhere that i can have a look at
cheers michael
Posted 22 October 2008 - 06:35 PM
i wish i had of seen this before i brought mine as i would of made one myself as this one looks sosimpy and strait forwardHeres a pic of an FRA alloy one on mine
cheers michael
Posted 22 October 2008 - 07:01 PM
bolts to standard subframe mount holes, but I drilled and added some more through the heal board just be sure lol.
Also it is very very light and wont rust
Edited by R.S.P, 22 October 2008 - 07:02 PM.
