1.8 K Turbo Round Nose
223 replies to this topic
#46 jackjewelljj
jackjewelljj
  • 241 posts
Posted 31 December 2015 - 11:17 PM
What?
#47 thelegg
thelegg
  • 608 posts
Posted 01 January 2016 - 11:29 AM
Not going to bother with shows to much effort lol
You need to come on some runs n stuff tho lol
#48 jackjewelljj
jackjewelljj
  • 241 posts
Posted 01 January 2016 - 11:55 AM
Maybe not sure yet
#49 tiger99
tiger99
  • 8,584 posts
Posted 01 January 2016 - 11:59 PM
As already suggested, your suspension setup is unsafe. The top pin of the coilover clearly is too short and does not pass fully through the nut, and the bracket attaching coilover to ball joint is causing inadequate thread engagement on the balljoint.
In any case the bracket is too thin and fatigue fracture is likely. These look like competition parts, utterly unsuited to road use, where mileages are higher and the fatigue problem more severe. These are likely to result in MOT failure as there is clear and obvious danger..
What size of bolt is holding the top mount, and what are they screwed in to?
Edited by tiger99, 02 January 2016 - 12:00 AM.
#50 jackjewelljj
jackjewelljj
  • 241 posts
Posted 02 January 2016 - 11:43 AM
******* this admin delete the build
#51 Broomer
Broomer
  • 1,771 posts
Posted 02 January 2016 - 06:51 PM
Tiger,
On what basis are those mounts not thick enough? Are these not the components fitted to every mini with coil overs?
Couldnt the ball joint issue be resolved by ditching the spring washer and fitting a nylock? If you can get about 1 dias worth of thread engagement with a nylock problem solved ?
#52 jackjewelljj
jackjewelljj
  • 241 posts
Posted 02 January 2016 - 06:54 PM
Cheers liam!
A friend of mine has done thousands of miles on the exact same set up never had a problem. If I really thought it was that unsafe I wouldn't use them and I'm sure spax wouldn't sell them.
#53 Broomer
Broomer
  • 1,771 posts
Posted 02 January 2016 - 07:03 PM
Plus not having that boat anchor A series sheds a load of weight at the front anyway.
#54 thelegg
thelegg
  • 608 posts
Posted 02 January 2016 - 09:47 PM
Haters gonna hate ;)
#55 jackjewelljj
jackjewelljj
  • 241 posts
Posted 04 January 2016 - 06:08 PM
Stripped all the paint off the rear part of the cage today and gave it a coat of paint just all the door bars ect to do. Also put the steering column back in. I've bought a set of plastic door cards that came with rear ones as well was going to use double sided tape to hold the rears on?
#56 jackjewelljj
jackjewelljj
  • 241 posts
Posted 06 January 2016 - 09:41 PM
Cage is all finished now and back in. Also got the rear cards on sticky tape didn't work so used a flexible mastic seems to work for now not sure how long they will stay on.
#57 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 12:06 AM
You need some "sticks like sh*t "
Edited by thelegg, 07 January 2016 - 12:07 AM.
#58 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 January 2016 - 07:48 AM
Its a similar thing but doesn't go brittle it stays flexible use it at work for a few things never failed.
#59 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 January 2016 - 06:16 PM
The cage needed persuading to fit the rear arches.
#60 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 06:33 PM
I had to do that on my cage also lol
Edited by thelegg, 07 January 2016 - 06:34 PM.
