1.8 K Turbo Round Nose
223 replies to this topic
#166 jackjewelljj
jackjewelljj
  • 241 posts
Posted 06 December 2016 - 09:28 PM
Bit more done, made up a flange for the coolant outlet on the top of the head and welded in some bits for the temp sensors, turbo oil feed and drain plumbed and the coolant pipes for the turbo, mounted the header tank, wired the alternator, just waiting on some heat reflective sleeve then the coolant system will be finished
#167 jackjewelljj
jackjewelljj
  • 241 posts
Posted 11 December 2016 - 08:22 PM
Started it up again today 1st time since I've mad the exhaust it's rather loud going to have to try and squeeze a silencer in it.
#168 thelegg
thelegg
  • 608 posts
Posted 12 December 2016 - 04:50 PM
Loud n proud !
#169 jackjewelljj
jackjewelljj
  • 241 posts
Posted 17 December 2016 - 04:59 PM
Made a start on the body work today took hours to strip the roof back to bare metal!
#170 jackjewelljj
jackjewelljj
  • 241 posts
Posted 17 December 2016 - 05:00 PM
Edited by jackjewelljj, 17 December 2016 - 05:06 PM.
#171 jackjewelljj
jackjewelljj
  • 241 posts
Posted 21 December 2016 - 09:36 PM
Bit more prep work done both door shuts sanded and primed, prep on roof is 99% done, stripped down both doors and the boot lid, also welded up the holes in the bonnet for where the badge is meant to be. Fcuking hate prep work!
#172 jackjewelljj
jackjewelljj
  • 241 posts
Posted 27 December 2016 - 04:45 PM
Started sanding the bonnet and found some surface rust under the paint so took it into work and sand blasted it.
#173 jackjewelljj
jackjewelljj
  • 241 posts
Posted 28 December 2016 - 12:34 PM
Had an epic fail with a brand new cambelt tensioner that I bought about a year ago and got round to fitting it today and it snapped! Didn't even make it to full tension. Had to buy another one and now it's all back together.
#174 CPC
CPC
  • 235 posts
Posted 28 December 2016 - 05:14 PM
Good job it snapped now rather than running
#175 jackjewelljj
jackjewelljj
  • 241 posts
Posted 29 December 2016 - 05:00 PM
Gave the front end a coat of zinc primer and couple layers of stone chip paint, made a start on the turbo support bracket also tried sorting the fuel leak on the fuel rail adapter couldn't stop it leaking turned out to be small crack in the fuel rail!
#176 jackjewelljj
jackjewelljj
  • 241 posts
Posted 31 December 2016 - 05:24 PM
Finished turbo support bracket and done bit more on the body prep
#177 jackjewelljj
jackjewelljj
  • 241 posts
Posted 01 January 2017 - 01:01 PM
Had a spare hour this morning wired up the fuel pump and made a start on the digi dash just waiting for a couple sensors then dash will be finished
#178 jackjewelljj
jackjewelljj
  • 241 posts
Posted 08 January 2017 - 10:13 AM
How do I upload a video?
#179 pinkmini99
pinkmini99
  • 563 posts
Posted 08 January 2017 - 10:17 AM
I uploaded mine to YouTube then you can just put the link on here
#180 jackjewelljj
jackjewelljj
  • 241 posts
Posted 08 January 2017 - 01:16 PM
