1.8 K Turbo Round Nose
223 replies to this topic
#1 jackjewelljj
jackjewelljj
  • 241 posts
Posted 20 November 2015 - 09:57 PM
So after doing a 1.8 kseries mini I've decided to buy a different shell and start again but this time do it properly!
plan for the engine is: custom manifold to put turbo over gearbox, garrett gt28rs turbo,z and f ecu, radiator in the rear.
So the shell has been tubbed de seemed flat boot floor, has been moddifed to use coilovers, remove able steel front needs no welding icon_smile.gif it was an a series turbo at some point
so far ive made the subframe, sorted gearlinkage, just another 1000jobs to do :(
Attached File  mini.jpg   61.32K   59 downloads
Attached File  mini2.jpg   71.88K   60 downloads
Attached File  mini6.jpg   59.03K   65 downloads
Attached File  mini5.jpg   61.03K   31 downloads
Attached File  mini10.jpg   74.44K   84 downloads
Attached File  mini9.jpg   78.14K   57 downloads
Attached File  mini12.jpg   53.53K   16 downloads
Attached File  mini14.jpg   34.51K   25 downloads
Attached File  mini8.jpg   61.75K   22 downloads
Attached File  mini7.jpg   48.22K   26 downloads
#2 jackjewelljj
jackjewelljj
  • 241 posts
Posted 21 November 2015 - 09:55 PM
Machined the shafts today just got to weld them now
Attached File  WP_20151121_13_19_31_Pro.jpg   39.62K   48 downloadsAttached File  WP_20151121_13_19_31_Pro.jpg   39.62K   48 downloadsAttached File  WP_20151121_10_43_02_Pro.jpg   25.61K   25 downloadsAttached File  WP_20151121_15_07_03_Pro.jpg   33.61K   36 downloads
#3 WestMidlandsMinis
WestMidlandsMinis
  • 25 posts
Posted 25 November 2015 - 03:29 PM
Looking good, will be following this, we have a 1.8k series build in the near future.
What's the plans on colour?
#4 jackjewelljj
jackjewelljj
  • 241 posts
Posted 25 November 2015 - 04:18 PM
Thinking of going for tweed grey with old English white roof
#5 thelegg
thelegg
  • 608 posts
Posted 03 December 2015 - 11:15 PM
Looking good mate
#6 jackjewelljj
jackjewelljj
  • 241 posts
Posted 04 December 2015 - 08:52 PM
Cheers just been reading through your build looks good. I need to get my ass in gear and get this thing finished
#7 mini13
mini13
  • 3,810 posts
Posted 05 December 2015 - 11:14 AM
just a  thought, but its worth considering the 1.4k over the 1.8 for turboing,
basically with a lot of boost you can get to the point where you split liners, the 1.4 has thicher liners so you can just throw boost at it if you take precautions against det ( water and mathanol injection)
Dennis/evolution in the link below has had great results on the 1.4 engine, and it would be wise IMO to look at his spec and emulate it, its all in the link, but basically 1.4 bottom end ( the one with forged pistons (mpi?)) uprated topcaps, turbo from a sunny gtir, 50/50 water/ meth injection and a ton of boost.
http://www.16vminicl...read.php?t=3208
#8 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 December 2015 - 09:14 PM
Thanks for the input but going to keep the 1.8
#9 jackjewelljj
jackjewelljj
  • 241 posts
Posted 14 December 2015 - 09:44 PM
Bit of progress done drive shafts welded, engine is on the stand ready for re-build also been buying parts type b lsd, omex rev limiter, small alternator, won't go on any more don't want to bore people to much
#10 jackjewelljj
jackjewelljj
  • 241 posts
Posted 19 December 2015 - 09:51 PM
Moved the car today, painted the frame and filled in the but I cut out the bulkhead
#11 jackjewelljj
jackjewelljj
  • 241 posts
Posted 20 December 2015 - 08:57 PM
#12 jackjewelljj
jackjewelljj
  • 241 posts
Posted 22 December 2015 - 11:20 PM
New rack fitted frame back in
#13 jackjewelljj
jackjewelljj
  • 241 posts
Posted 23 December 2015 - 10:03 PM
Got the inside all cleaned up today managed to get a coat of primer on it going to put top coat on tomorrow.
#14 thelegg
thelegg
  • 608 posts
Posted 23 December 2015 - 10:53 PM
Looking smart
#15 jackjewelljj
jackjewelljj
  • 241 posts
Posted 23 December 2015 - 11:07 PM
Getting there slowly moved the car to chard now do don't have to drive out to merriot anymore :)
Plan before I go back to work is:
Rebuild engine
Rebuild drive shafts
Paint inside of car
Strip and paint underneath the car
