THERMOCURE removes rust scale and deposits from radiators, water pumps, water jackets, engine blocks, and heads. Rust and corrosion act as an insulator and cause vehicles to overheat.
Edited by Frost Auto, 20 November 2015 - 09:18 AM.
Posted 17 November 2015 - 10:05 AM
Posted 17 November 2015 - 10:22 AM
A comment. there is no info as to how much (or little) this does.
is the 135 Quid purchace a one shot job?
or is it an add to current coolant at a percentage of?
or.......
if one jug will do more than one car i may be interested. but at the moment it just seems very expensive.
Posted 17 November 2015 - 11:28 AM
might be an idea to add the use instructions as it makes it seem more value than it is now.
Edited by nicklouse, 17 November 2015 - 11:28 AM.
Posted 17 November 2015 - 11:37 AM
1. Drain cooling system and rinse with water.
2. Fill system with Evapo-Rust®. (Do NOT dilute.)
3. Run Engine under normal conditions, shut engine down and let sit, for a couple hours to overnight.
4. Drain system into a container for later use.
5. Flush system with water.
6. Repeat process (1-5) if necessary.
7. Fill system with proper coolant/antifreeze.
Fill the system with Evapo-rust?
You'd need 4 bottles of it
Posted 17 November 2015 - 11:38 AM
Nick you're right needs more info
I don't think I understand - it says fill with Evapo-Rust (do NOT dilute) but the bottle is less than a litre. At £135/bottle its is going to be a very expensive process surely?
And I presume when it says save for later use - is that just to repeat the steps, not to do it again on other cars?
Posted 17 November 2015 - 11:42 AM
from what i have read you can use it in as many cars as you want.
but yes expensive. almost cheaper to strip the engine down and send for a chemical clean. (almost is maybe wrong. 5 liters is a new short motor).
more i think the less apeal it has.
Posted 17 November 2015 - 11:44 AM
different info
Features
Posted 17 November 2015 - 11:46 AM
Posted 17 November 2015 - 01:25 PM
guys just click on the link, the price is 14,99£/bottle!!
Posted 17 November 2015 - 02:02 PM
they have corrected the error in the priceing.
Posted 17 November 2015 - 02:23 PM
and only since we have been discussing it - it was wrong at lunchtime!
