Yet Another Electrical Question. Rating Of Switches.
Posted 17 November 2015 - 12:07 AM
Yet.
So switches you know like we like to fit for accessories etc. Some times we will use a relay and other times a relay is not needed.
I remember the ilium instead plastic toggle switches I used for the spots and fogs in the old days ( they are still available) were rated at 30 A and we ran a relay. Ok current is easy to work out what is needed.
But to the actual question let us say we have a toggle switch that is listed as 250V 10A what would the rating be in a 12V situation?
Presuming that 250V is AC and the 12V is DC. Not sure what else it could be.
Posted 17 November 2015 - 09:13 AM
Hi Nick It will probably halve the current load so I would reckon about 5amp., due to AC switching and DC being constant
Posted 17 November 2015 - 09:53 AM
That may be acceptable if it is DC Rated.. but please read the following
To err on the side of safety, read the specifications thus:
Rated to allow up to 10A at up to 125VAC or up to 6A at up to 250VAC. Not actually rated for DC, so you're on your own.
In other words, if at all there is a choice, opt for a DC-rated switch, so you know you are within rated parameters. If, however, that is not an option, read on...
Some of the factors that affect a switch contact rating:
- Voltage at which breaking the contact will not cause unacceptable arcing / pitting
- Voltage at which the isolation provided by the switch housing starts getting unsafe
- Current at which the contacts will not overheat enough to melt or damage the housing
- AC or DC voltage: AC signals are easier to break, i.e. less contact pitting or arcing, since the potential difference falls to zero twice per cycle.
Thus, when used for DC, I prefer to assume 10% of the highest rated AC voltage, while keeping the current rating the same as the lowest rated current for the AC specifications.
For this particular switch, 6 Amperes at 12.5 Volts DC would not trigger a paranoia attack.
Posted 17 November 2015 - 09:59 AM
Switches are rated on the amount of current they can switch without welding the contacts together. This is why a relay is used as the switch only controls the relay coil and the heavier current passes through the relay contacts (which can be switched at very high speed to avoid arcing). This is why relays are used in car systems such as wiper motors, lights,etc which have a relatively high power rating.
Posted 17 November 2015 - 01:57 PM
I get whats the point of your question
Yes 10A AC are 10A DC and you'll open a can of worm if you ask this at the uni
The actual problem will be knowing how the switch is rated for 10A and how long do you want the switch to last
Posted 17 November 2015 - 08:25 PM
Zero crossing point is when the voltage is zero as it changes direction at 120 times a second.
Switches in a DC circuit have to extinguish the arc as there is no zero crossing point.. Most have a snap action to separate the contacts rapidly and far enough apart to break the arc before it can damage the contact surfaces.
As a rule of thumb treat 240v AC switches amperage at a maximum of 20% (divide by 5) of the AC amperage marked on the switch on a DC Circuit
So a 240v AC 10amps switch would only be safe on a 12v DC circuit at 2amps, what usually happens is the switch arcs and welds the contacts together and your unable to switch the circuit off. This is worse when a AC switch is used for example a DC fan motor where the voltage spikes during the on/off switching due to the motor windings
Edited by KernowCooper, 17 November 2015 - 08:37 PM.
Posted 17 November 2015 - 11:14 PM
So to sum it all up as I see it.
The design of the two types of switch should be fundamentally different do to the lingering spark in the DC system.
So there is no way to safely scale the numbers.
BUT using an AC switch should be OK. To trigger a relay or for a relatively low draw application.
So from my collection of switches some have been used before without relays and were fine but we know how that can end.
I will be running the feed to the ignition system via a fused circuit and a 15A 250v switch. The fuel pump, facet red top 5A supply needed via the same set up. Stater relay will be triggered by an unfused circuit and a suitable MOD 12v mom switch.
Rad fan and water pump and wipers will all be powered via 30A relays triggered by 10A 250v switches. Again fused. All covered by a big cut off switch.
Doing it right is different to just doing it.
Posted 18 November 2015 - 12:12 AM
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
