Vinyl Glue - What's Best?
9 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 16 November 2015 - 02:18 PM
HI,
What's the best stuff to stick vinyl to the back of door cards or the parcel shelf? I used spray on evo stick but its gradually coming unstuck.
What works for the long term?
Thanks,
Rod
#2 1984mini25
1984mini25
  • 8,784 posts
Posted 16 November 2015 - 03:25 PM
If you can deal with the smell, evo stik impact contact adhesive in the tins is pretty good. Although with both the spray and brush on types, apply the glue to both surfaces if needed and allow to dry/go tacky before sticking.
#3 briancaveman2003
briancaveman2003
  • 197 posts
Posted 16 November 2015 - 03:41 PM
yes good stuff we use it at work to stick flooring down on bus floors
#4 Almond-1
Almond-1
  • 203 posts
  • Local Club: Cooper Register
Posted 16 November 2015 - 08:29 PM
I assume that the backing is thin hard board. If so try roughing up the hard board with 80 grit prior to applying the glue. As stated ensure that you apply the glue to both sides.
#5 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 16 November 2015 - 09:32 PM
Dunlop Thixofix
#6 Davey3legs
Davey3legs
  • 36 posts
Posted 16 November 2015 - 11:26 PM
As said above, evo stick impact adhesive, its what was used where i worked years ago, you shouldn't need to scuff the surfaces up either. Just remember if its fairly fresh, apply it to both surfaces and allow it to tack off for a minute or two before pushing the fabric/vinyl/leather down onto the surface. Used to use it for carpet also, but was best to use tins that had already half gone off as the carpet has a lot more tension on and will just pull away from the surface if the glue isn't tacky enough.
The technique i was taught by trimmers a long time ago: a plastic scraper (like the ones you get with tins of bodyfiller), get a little bit of glue on the underside of it, and swipe along the surface to be glued in a C shaped movement all the way along. (CCCCCCCCCC).
Hope this was of some use.
#7 rodandtom
rodandtom
  • 998 posts
Posted 17 November 2015 - 07:19 PM
Thanks all. I used evo stick the first time around, but as I said in the OP - it's coming away. That's why I thought it might be better to use something else.
Rod
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 17 November 2015 - 09:26 PM
Evostick do a product called sticks like sh!t in a clear that will stick anything to anything. It's awesome. I've hung up some curtain frames with this stuff and its stuck extremely well.
#9 blacktulip
blacktulip
  • 6,224 posts
#10 1984mini25
1984mini25
  • 8,784 posts
Posted 18 November 2015 - 12:35 PM
Rod
The tinned is a lot better than the spray can variety.
