Right, finally had chance to stick my cooper s set up on my mini but got stuck after loosely fitting the top ball joint nut.
I'm left with this:
The hub is sitting at funny angle.
After a sulk, packing everything away, raiding my parents kitchen for sweets and a google, i'm come to the conclusion that the drive shaft may need whacking a bit further into the pot joint. Does this sound about right?
It may have moved when I was getting the old drum cv joints off the drive shaft as when I started wiggling and jiggling it I got this:
Have I possibly caused any damage? Is there a seal in there that I may have dislodged? Would it be best to cut the rubber boot off to inspect and re-grease? What will I most likely be greeted with?
Thanks in advance,
- Rich
