Rolling Snot
890 replies to this topic
#736 miniallsort
miniallsort
  • 4,723 posts
Posted 18 July 2008 - 05:54 PM
nice why do you want 2 tanks ?
#737 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,851 posts
Posted 18 July 2008 - 05:57 PM
phoooaaarrr! i always wanted 2 tanks but as you have demonstrated .. it obscures the battery
#738 kcchan
kcchan
  • 874 posts
Posted 18 July 2008 - 06:08 PM
Damn. If Iknew that it was that easy, I would have kept the tank and bought another for myself. Ohwell, alloy fuel tanks are muchos cooler.
>_<
EDIT: seeing as you not using the rear seats, you could just mount the battery inside the car. Your choice though
Edited by kcchan, 18 July 2008 - 06:09 PM.
#739 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 18 July 2008 - 07:56 PM
Yea as said iv still got a bit more hammering to do, so i think ill be able to get it closer to the body by a couple of inches to give the clearance for the battery. and if i cant get the clearance ill just move the battery to where the spare wheel would usually go, as i dont ever carry a spare wheel... But again i will need a spare or 2 for germany... The reason im having twin tanks is so i can hold more fuel for germany really lol, and it should help keep the weight more level on the rear :thumbsup:
Also i just picked this baby up from the same guy i got the webber from, and he might also be sorting me out with a full rollcage:
I then though i would quickly stick that on before we lost all light:
So now ill do the fine adjustment of the cam using the little gauge on the push rod, a gasket on the outer cover an stick it all back together and now the engine should be leak free lol.
Also i pushed the pot joint back in place and it sounded like it located this time :dontgetit:
Edited by Tomf, 18 July 2008 - 07:59 PM.
#740 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 19 July 2008 - 09:17 PM
:thumbsup: all timed up and back together now
And finally i have no oil leaks :) :thumbsup: :( Well from what i can tell after the car ideling for about 30 mins... Didnt get any pics though as my phone had no battery :dontgetit:
Ill wack the front end on tomorrow and get some milles clocked up :(
Still unsure what carb to use, either twins or the webber :thumbsup:
Ideally i want to have the new carbs on and set up on a rolling road before germany, but i dont know if thats going to be possible as im going to cornwall with a load of mate the week before germany so not got much time... still trying to sorce some front legs for the rollcage, but the guy i got the webber and timing set off had loads of cages for racing, but isnt sure if hes selling any yet, so ill get on to him in a couple of days and see what happens...
#741 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 19 July 2008 - 11:38 PM
Fust found a couple of pics i took the other day :wub:
#742 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 21 July 2008 - 12:14 AM
Looks like this is going to be one thirsty engine i just worked out using the current carb and with me still running the engine in, so not going over 4000 revs im only getting 26mpg, so when i put the new carbs on there going to be drinking more fuel and ill soon actually be able to put my foot down, so thats going to make that go a hell of a lot lower :)
#743 miniallsort
miniallsort
  • 4,723 posts
Posted 21 July 2008 - 12:51 AM
nice wrk mate
#744 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 21 July 2008 - 02:57 PM
Well the twin carbs came through the post today and after being in contact with ACDodd at MLMotorsport and telling him my full engine spec he advised me to use AAA needles and a red spring, so i had a search through the internet and found some red springs, but i couldnt find anywhere that sold any AAA needles, but after a strip down of the carbs today i found they already have AAA needles fitted >_< so thats going to save me a hell of alot of hastle :w00t:
Just got to find a manifold to get them on the mini now :shy:.
#745 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 22 July 2008 - 10:26 PM
Well i got the satnav fitted:
Also i got a nice big two parcels through the post today :D
So ill get some nitromorse on them tomorrow as the lacqure is flaking off, and give them a quick wet and dry and see how they come up.
They need defonately need 1 but probably two new tyres, but thats not to much of a problem. I also recived som nuts that i brough of someone on here, well atleast i think i did i got the parcel felt it and guessed it was them and didnt open it lol.
Should be cleaned up and on the mini soon :(
Edited by Tomf, 22 July 2008 - 10:26 PM.
#746 mike.
mike.
  • 6,176 posts
Posted 22 July 2008 - 10:36 PM
How is the satnav held in place?
#747 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 22 July 2008 - 10:43 PM
Just velcro (sp) so i can take it off it its being parked in some unsafe places, i was going to screw the mounting bracket in place, but this looked really ugly when the satnav isnt in place.
#748 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 23 July 2008 - 11:28 AM
nitromorsed one of the wheels this morning and it looks like they will clean up nice :D
#749 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 23 July 2008 - 11:29 PM
Well on the nitromorse went:
And off came the lacqure and paint:
Well the lacqure and the paint in the middle came off easily, but the paint between the spokes didnt have a single sign of shifting, so im not sure what that is, so ill just sane that back and re-paint.
Also i fitted a oil cooler today as the temp gauge was reading high:
But although that helped with the engin temp a bit it was still running a bit hot, so iv not ordered a thermostat blanking sleve. And ill drill out the head to accept the heater tap and ill plumb this in along with my heater matrix to hopefully reduce the temp a bit more. I think its running hot becuase the rings are still bedding in causing quite a bit of friction thus causing more heat.
hopefully it will be sorted soon tho :D
#750 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 24 July 2008 - 10:54 AM
Looking better than ever Tom, well done mate !
