K1380 Twink, Smooth And Tucked Bay, Spit Rims With All The Nice Bits. (Work In Progress)
roundnose
113 replies to this topic
#76 Jayme 1275
Jayme 1275
  • 488 posts
Posted 24 August 2016 - 09:26 PM
 Have you worked out a way to make the throttle cable work with the ITG panel?  would be interested to to see your solution.
yea its spaced so the throttle quadrant pulls around without hitting the plate.
Throttle quadrant? Don't think mine has this, Ive been looking at changing to a similar filter but can't think of a way to attach the cable.
Any chance of any more pictures, close up please?
Im going to make a bracket to direct the cable on to the quadrant from underneath, then set it so when you push the pedal it pulls the cable down thus opening throttles.
Got my floor painted again, completely bare metaled it Sprayed it with epoxy primer then upol raptor. Really pleased with finish.
Really happy with the results, is exactly how i wanted. Next up is possibly another coat or 2 in places and start prepping the bay and interior for paint. Have a friend who worked in a high end body shop coming to help with that so it should be done to a very high standard.
Cheers for looking
Jayme
#77 Richie83
Richie83
  • 1,495 posts
Posted 24 August 2016 - 09:36 PM
Cheers for looking
Jayme
brilliant. I'm doing the same to mine. How much raptor did you use?
#78 Jayme 1275
Jayme 1275
  • 488 posts
Posted 26 August 2016 - 06:32 PM
Approx 2 and a half bottles Richie, i thinned it the 10 percent and added 10 percent base coat before putting it on @60psi on a hvlp gun. I will probably scuff it up and apply a few more coats to be honest
#79 Daz1968
Daz1968
  • 2,058 posts
Posted 26 August 2016 - 09:08 PM
I am hoping to use raptor on my cars underside, what size gun did you use, largest one I have is 2.0mm if this isn't large enough will probably try it with shutz gun.
Looks good though, when mixing is it just normal 2k direct gloss mixed with it.
#80 Jayme 1275
Jayme 1275
  • 488 posts
Posted 26 August 2016 - 10:30 PM
Gun size was 2.0mm
I used base coat mate, read instructions and it suggests 2k may be better, never saw this to after
#81 Daz1968
Daz1968
  • 2,058 posts
Posted 26 August 2016 - 11:32 PM
Thanks, thing I like about raptor is the colour is in the stonechip so hopefully any small damage from use will still be body colour, also as it's 2k should be hard wearing and less likely to cause reactions than cellulose based stonechip. Think I will give it a go a jawel a now sell it in 1 litre packs whereas normally comes in a larger pack.
#82 Jayme 1275
Jayme 1275
  • 488 posts
Posted 27 August 2016 - 11:24 AM
The whole kit cost me 90 quid a few weeks back, it was the first time ive ever sprayed it and it looks brilliant imo. Im going to apply the whole kit when ive it up on the jig so will scuff it up and reapply next weekend, ive scrapping some of it with my nail and its well solid.
#83 Jayme 1275
Jayme 1275
  • 488 posts
Posted 11 October 2018 - 06:25 PM
Well almost 2 years since my last post I decided that I really want this finished at the start of the year and ive been steaming along nicely.
Interior got painted
22127403_1909415479073614_1660355748_n_z
22127360_1909415865740242_1282234142_n_z
22156847_1909415419073620_230808152_n_zp
Sorted the dash
24891681_1982151871799974_1205860029_n_z
and some other parts of the interior, or lack of interior
Reworked the grill so it now is quick release instead of the self tapping screws, from here I got a new bonnet and mounted it up on some leather straps and pitking quick release fixings on the rear.
#84 Jayme 1275
Jayme 1275
  • 488 posts
Posted 11 October 2018 - 06:33 PM
The underside also got redone as I wasnt happy with it
Everything from the underside was stripped fully, blasted and repainted. When I done this i replaced all bolts and 99% of everything else that bolts on
#85 Jayme 1275
Jayme 1275
  • 488 posts
Posted 11 October 2018 - 06:37 PM
43667923_177647476447145_453298898906539
All lower arms fitted, mini spares camber arms with KAD tie bars and owens ball joint droppers
#86 Jayme 1275
Jayme 1275
  • 488 posts
Posted 11 October 2018 - 06:43 PM
Then onto possibly my favorite part of the car, the engine bay
Then I checked arch clearance again on the front, so the rims came back out
Tried on some new door mirrors
#87 Jayme 1275
Jayme 1275
  • 488 posts
Posted 11 October 2018 - 06:46 PM
This led to me and my mate building up the gearbox
40194782_1924970157570220_59025515689552
Spec wise it a full straight cut close ratio set, with a quaife diff and a 3,2 fd. Needless to say everything else that can be got was also replaced while building it.
#88 Jayme 1275
Jayme 1275
  • 488 posts
Posted 11 October 2018 - 06:56 PM
Then needed to look about the engine, shipped this to SC to be converted plus for them to convert the crank to their spec.
42513387_10160854963930285_2645697058312
42568185_10160854968030285_5055867468845
42619827_10160854963955285_8687582541785
Spec wise its going to be
1380cc
sc spec crank
sc rods
73.5 omegas
fully dry decked block and head
SC dry deck head gasket
SC spec head
Gas flowed
BMW ITB's and SC Manifold
#89 Richie83
Richie83
  • 1,495 posts
Posted 12 October 2018 - 06:36 AM
Good that things are progressing mate. The photos aren’t showing for me though :-(
#90 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 12 October 2018 - 07:44 AM
Odd, when I hit refresh the photos pop up for a moment, then disappear again.
