Mini Se7En Racer Build
34 replies to this topic
#16 Tupers
Tupers
  • 4,156 posts
Posted 05 December 2015 - 04:25 PM
No you need some proper structure in there to support the pedal box. Check out Charlies thread for his last car. Clicky
10456105_764798560273657_625204397601108
#17 charliebudd
charliebudd
  • 429 posts
Posted 05 December 2015 - 05:23 PM
I know they are floor mounted I know you wouldn't actually attach them to the bulk head lol
I just wanted to know how much clearance there was between the toe board and the master cylinders. But as you sit quite far back in the car I take it it's not much of an issue.
Is there anything you would need to do to the floor in order to strengthen it or just a matter of using large washers to spread the load out ?
As mentioned in the above reply, you need some kind of structure there. Endaf has done my
New one a different way this year. I will add photos when i collect the car
#18 James_eaton_thewholething
  • 1,063 posts
Posted 05 December 2015 - 06:56 PM
Cheers for sharing the picture.
If I use some box section and make up some brackets to pass the bolts through and weld them to the box section then weld the box section to the tunnel inner wing and the floor would this be ok. Or can I just weld some box section or thick flat bar to the floor wider than the pedal box and pass bolts through to a captive spreader plate underneath ?
Sorry for the questions just want to know before I buy all the stuff and get on with it.
Edited by James_eaton_thewholething, 05 December 2015 - 07:49 PM.
#19 charliebudd
charliebudd
  • 429 posts
Posted 06 December 2015 - 11:22 AM
Ask away mate, but to be honest im probably not the best person to ask. There are people on here who could advise better then me
#20 James_eaton_thewholething
  • 1,063 posts
Posted 06 December 2015 - 04:43 PM
Cheers. I will look out for updates on this. It will be nice to see how different they have mounted the pedal box. Thanks for replying
#21 charliebudd
charliebudd
  • 429 posts
Posted 07 December 2015 - 10:54 AM
a little preview of the work being done on the shell,
12313544_1014409428582454_58524215406630
#22 charliebudd
charliebudd
  • 429 posts
Posted 20 December 2015 - 06:29 PM
The dry build on the car has been complete and it is now in the hands of the paint shop, look forward to getting it back early jan
#23 charliebudd
charliebudd
  • 429 posts
Posted 26 January 2016 - 05:30 PM
Its been a while since i last posted... 2 reasons.. we wanted to keep some of the bits off the internet until the autosport show and we have been absolutely manic with trying to get the car ready. owens fabrication have done great job of the cage and fabrication, the real mini company have done all the bodywork and I'm chuffed to bits with it. we have gone down a different route to last years car and tried to keep everything clean and uncluttered , minimalistic. Fusion Fabrications have made up an exhaust and inlet for us try on the Dyno with KAD, looking forward to making steps forward in 2016.
we had our awards evening last weekend - and received trophies for 10th in championship, best prepared car (last seasons car) & best newcomer.
car is now back in the garage and the first test day is booked for 4th march , lots to do before then !
#24 James_eaton_thewholething
  • 1,063 posts
Posted 26 January 2016 - 06:15 PM
What colour grey is that because it's beautiful
#25 charliebudd
charliebudd
  • 429 posts
Posted 26 January 2016 - 07:25 PM
Yukon grey gr7
#26 GraemeC
GraemeC
  • 7,440 posts
Posted 26 January 2016 - 07:26 PM
Who makes the catch tank?
#27 charliebudd
charliebudd
  • 429 posts
Posted 26 January 2016 - 07:27 PM
Owens fabrication find them on facebook mate, they do loads of good stuff. If you do speak say your see this build on tmf
#28 GraemeC
GraemeC
  • 7,440 posts
Posted 26 January 2016 - 09:47 PM
I'll contact them - I want a small fuel tank in the same location.
#29 Baldspeed Racing
Baldspeed Racing
  • 1,195 posts
Posted 27 January 2016 - 07:37 AM
She looked spot on at the show dude fair play, roll on Castle Combe ;)
#30 charliebudd
charliebudd
  • 429 posts
Posted 27 January 2016 - 08:41 AM
Good stuff, they do a lot of custom bits. well worth a call
Cheers mate, really pleased with her, excited to get out on track now  !
