he should have this
http://www.minispare...c/mpi.aspx|Back to search
Posted 11 December 2015 - 02:13 PM
Posted 11 December 2015 - 02:31 PM
Posted 11 December 2015 - 02:36 PM
Hi Nick,
Sorry didn't see your post, yes that's what I can't get loose. Obviously difficult to access as you have to go from underneath
Posted 19 December 2015 - 10:07 AM
So had another quick go at the Manifold again this morning and it's off!! Looks like the wd40 combined with some very extravagant lever work got those three nuts loose. Ready to crack on with actually installing the new stage 1 kit now (finally). I actually didn't need to take off the engine steady arm as I thought I would have to but looking at it the bushes need replacing. I've taken the nut off the bottom but the bolt won't budge. Any advice on shifting this so I can replace the bushes?
Posted 19 December 2015 - 02:21 PM
Mini Technical Sections →
Problems, Questions and Technical →
Lower Radiator Bracket Fitment IssuesStarted by DAC1952 , 09 Mar 2025 ![]() |
Automatic GearboxStarted by astracass , 25 Feb 2025 ![]() |
Start Motor Grind No Engine Turn OverStarted by MrNowell , 16 Feb 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
