Furry Micra Mini
324 replies to this topic
#121 thelegg
thelegg
  • 608 posts
Posted 12 January 2016 - 11:48 PM
Right well I spent pretty much the whole of my evening removing my pedal box which was slightly seized but never mind got it out after a lot of swearing and unseized it without any trouble, so that's all ready for modification sometime for cable clutch,
Then I slopped some primer onto my frame just to keep the rust away :)
Also my new brake master cylinder turned up today :) so can start plumbing my brakes back in soon, my Suzuki swift alternator also turned up but no one was in to sign for it :(
Edited by thelegg, 31 October 2017 - 02:52 PM.
#122 thelegg
thelegg
  • 608 posts
Posted 13 January 2016 - 11:30 PM
Fitted the frame today roughly
Then realised that I'd have to remove the tower bolts again in order to fit my suspension :(
Edited by thelegg, 31 October 2017 - 02:54 PM.
#123 thelegg
thelegg
  • 608 posts
Posted 17 January 2016 - 11:51 PM
We are rolling :D
Bought some KAD calipers 2nd hand on eBay like 5 months ago for £210 but when they arrived they came with practically new discs and green stuff pads :) and a full hub assembly lol but upon further inspection they've got strange hoses, anyone seen anything like this before ?
Anyway I thought I'd just remove the hoses and swap them for the ones on my old metro 4 pots but turns out that's a different thread as well so now I've got to wait for some standard mini hoses to turn up :( so I couldn't finish plumbing in my brakes but got all the tricky bends done just need to make a long pipe that will go over to the passenger side front brake.
Soon as my new braided hoses turn up I can finish off my brakes but in the meantime the engine can go back in :) so that I can sort my gear shift out
Edited by thelegg, 31 October 2017 - 03:02 PM.
#124 jackjewelljj
jackjewelljj
  • 241 posts
Posted 18 January 2016 - 07:48 PM
How close will your frame be to the road?
#125 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 18 January 2016 - 08:03 PM
That looks like its going to be very close to the ground!
#126 thelegg
thelegg
  • 608 posts
Posted 18 January 2016 - 09:58 PM
At the moment the hi los are wound right in to there lowest setting so it will be higher lol although it's not as low as you think
#127 jackjewelljj
jackjewelljj
  • 241 posts
Posted 18 January 2016 - 10:34 PM
Will be interesting to see looks good. The frame I made for the 1.8mini it sat 25mm lower than the floor pan line and that was close to the ground car wasn't stupidly low either
#128 thelegg
thelegg
  • 608 posts
Posted 18 January 2016 - 10:54 PM
The way I see it modern cars are quite low and the lowest part of my frame is right next to the wheels but we shall see haha can always do part time work in the winter as a snow plough ;)
#129 thelegg
thelegg
  • 608 posts
Posted 19 January 2016 - 11:27 PM
Well it's in!
Clearance from the floor is 100mm at the lowest point of the subframe but this is with the hi Los as low as they will go obviously it will be higher but even with it this low the frame will clear the floor even if I was driving on my bump stops
New brake pipes turned up this morning so shall finish brakes tomorrow after work, all in all very happy with tonight's efforts
Edited by thelegg, 31 October 2017 - 03:07 PM.
#130 l_jonez
l_jonez
  • 1,453 posts
Posted 20 January 2016 - 06:17 PM
Hi-lo's should go much lower than that, you got a big gap between the arms and bump stops.
#131 thelegg
thelegg
  • 608 posts
Posted 20 January 2016 - 06:36 PM
Well the only way they'd go lower is if I took the locking nut off ! It's got new(ish) rubber doughnuts fitted which are settling slowly, I don't want it really low anyway spec I'll higher it up as I've got about 2" of travel before it will hit the bump stop which doesn't seem like much
#132 jackjewelljj
jackjewelljj
  • 241 posts
Posted 20 January 2016 - 06:41 PM
That's loads I had to cut my bump stops in half had less than an inch between the arm and stop
#133 jackjewelljj
jackjewelljj
  • 241 posts
Posted 20 January 2016 - 06:42 PM
What's it like with the front on
#134 thelegg
thelegg
  • 608 posts
Posted 20 January 2016 - 06:48 PM
Haha haven't even got the front end on the same premises at the moment but I will need to get it here sooner rather than later as I need to check clearences for radiator n stuff
#135 jackjewelljj
jackjewelljj
  • 241 posts
Posted 20 January 2016 - 06:54 PM
You keeping round nose or going clubman?
