Furry Micra Mini
324 replies to this topic
#106 thelegg
thelegg
  • 608 posts
Posted 05 January 2016 - 06:55 AM
Quite a lot if you can see on my pictures
Holy sh*t you've dented it in loads lol don't think I need to go that extreme!
Jon good to hear your back in the mini scene your new build looks great :)
Right then small update bit of reinforcing done today, first bit was at the top of the towers
20160104_151916_zpsk86no9xe.jpg[/URL]
2nd bit was inside the towers
Hopefully they should be nice and strong again now :) apart from my bottom arm mounts any ideas if I need to reinforce other areas ?
put the top arm in and check for twist in the tower. Noticed a bit in outs so cut a bit of 20x20 box in half and curved it around the outside :-)
Any pics ?
#107 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 05 January 2016 - 12:15 PM
Here :-)
#108 thelegg
thelegg
  • 608 posts
Posted 05 January 2016 - 05:23 PM
OK that makes sense now although mine doesn't seem to flex :/
#109 Shingler4596
Shingler4596
  • 221 posts
Posted 06 January 2016 - 10:17 PM
It may be because it looks like we've cut more out of the bottom of the towers as you still have majority of the hole for the driveshaft. As you progress just keep checking clearances and any movement in the frame. I think the only thing I can see that probably.won't clear with you is the pot joint closest to the tower and the longest driveshaft but we had the same problem. Just a quick adjustment and it was sorted :-)
#110 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 12:05 AM
I did try the pot joint in my engine quickly and all it touches was the nut holding my bottom arm in but it wasn't done up so I doubt it will touch at all once fully tightened, maybe our engines are positioned slightly different ?
#111 Shingler4596
Shingler4596
  • 221 posts
Posted 07 January 2016 - 12:06 AM
If that's the case yours is probably a lot lower than mine. Would be interested to see how much lower :-)
#112 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 07:04 AM
Hey guys was just thinking about my brake setup, obviously I'm ditching my servo due to lack of space and also because it doesn't really do much haha so am I right in thinking that the only difference between my pedal box and one from a non servo mini is that the clevis pin in my brake pedal is bigger diameter ? Or is the actual pedal a different angle n stuff ?
#113 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 January 2016 - 09:40 AM
The clevis pin hole is bigger I did the same thing to my other mini. Just made a metal bush to fit and welded it in place. Worked fine
#114 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 05:00 PM
Cool just I'd read somewhere that the pedals were different so if the servo was swapped out for non servo master cylinder the pedal wouldn't have enough travel on it
#115 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 January 2016 - 06:13 PM
I had no problem with mine. Just had to make the clevis pin hole smaller
#116 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 06:32 PM
Cool I'll just weld it up and re-drill the hole then :)
#117 l_jonez
l_jonez
  • 1,453 posts
Posted 07 January 2016 - 07:43 PM
Fairly sure the holes are in slightly different positions.
#118 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 January 2016 - 07:45 PM
I converted mine worked perfectly
Edited by jackjewelljj, 07 January 2016 - 07:47 PM.
#119 jackjewelljj
jackjewelljj
  • 241 posts
Posted 07 January 2016 - 07:52 PM
All I did was machine up some steel to match the o.d of the hole in the pedal and drilled a hole in the centre to allow the clevis pin to fit. Then welded it to the pedal
#120 thelegg
thelegg
  • 608 posts
Posted 07 January 2016 - 11:19 PM
Almost finished the back of my frame just got to add abit more strength to the floor mount area and then it will be ready for the first time fit to my mini :D also need to remember to cut off the bits of bar i welded to the towers for attaching it to my jig
Edited by thelegg, 31 October 2017 - 02:49 PM.
