Furry Micra Mini
#76
Posted 03 December 2015 - 11:29 PM
#77
Posted 04 December 2015 - 12:03 AM
Hmm I agree mine does judder somewhat at low revs, but blipping the throttle is like a motorbike! :)
#78
Posted 04 December 2015 - 06:44 AM
#79
Posted 04 December 2015 - 01:17 PM
Posted 04 December 2015 - 01:23 PM
Here's a pic of another option :
http://i376.photobuc...zpssfgqcmei.jpg
http://i376.photobuc...zpsa3hexhym.jpg
#81
Posted 04 December 2015 - 04:40 PM
Edited by thelegg, 04 December 2015 - 04:48 PM.
#82
Posted 04 December 2015 - 04:54 PM
#83
Posted 11 December 2015 - 11:00 PM
Tried to update this last night but photo bucket wasn't behaving so attempt 2 lol, roughly tacked in the bars running underneath my subframe
And then I started making my front crossbar for my subframe, it's going to be removable to make fitting and removing my manifold/exhaust easier
Will hopefully do abit more tomorrow
Edited by thelegg, 31 October 2017 - 02:22 PM.
#84
Posted 13 December 2015 - 01:33 AM
Finished the crossbar off and bolted it on
Also noticed that the box section running from the tower to the front of the subframe on the right hand side was very squewiff so I decided to chop it out and reweld it, didn't get any pics but a lot happier with it now :) didn't get anything else done as I was going out for the evening with some friends so had a tidy up ready to resume on Monday, plan to remove the tie bars and bottom arms from my other subframe still mounted to my mini so I can trial fit them to my modified frame just to make sure everything clears
Edited by thelegg, 31 October 2017 - 02:24 PM.
#85
Posted 17 December 2015 - 06:43 AM
Update :)
Started making new bolts for my bottom arms
Obviously still need to weld it together yet lol
Bolt will go through from the back and the head will be locked in place with another piece of flat metal to stop it turning and undoing its self
Still need to weld another plate the other side for the bolt to go through
Edited by thelegg, 31 October 2017 - 02:29 PM.
#86
Posted 22 December 2015 - 10:42 PM
Last update till after Xmas I spec
Managed to finish my bottom arm mounts apart from adding in some bracing/reinforcing later on when I seam weld the rest of my frame together, Snapped my 1/2" drill bit as well good job it was on the last hole!
Next job will be to take the engine back out so I can weld the frame together properly and add in some reinforcing bits :)
Edited by thelegg, 31 October 2017 - 02:31 PM.
#87
Posted 29 December 2015 - 09:51 PM
#88
Posted 29 December 2015 - 10:02 PM
#89
Posted 29 December 2015 - 10:07 PM
#90
Posted 30 December 2015 - 09:04 AM
