Furry Micra Mini
#256
Posted 30 April 2016 - 03:28 PM
#257
Posted 11 May 2016 - 08:21 PM
#258
Posted 19 May 2016 - 05:26 PM
#259
Posted 12 June 2016 - 02:22 PM
Edited by thelegg, 01 July 2017 - 09:20 PM.
#260
Posted 28 June 2016 - 11:16 PM
Edited by thelegg, 01 July 2017 - 09:22 PM.
#261
Posted 29 June 2016 - 07:44 AM
Edited by thelegg, 29 June 2016 - 10:43 PM.
#262
Posted 29 June 2016 - 08:24 AM
Will you be keeping the dash furry? As long as no animals are harmed in the making of the dash!
#263
Posted 29 June 2016 - 10:39 PM
Afraid it's going to be carbonfibre when it's finished but there will still be furry aspects in the mini :)Will you be keeping the dash furry? As long as no animals are harmed in the making of the dash!
#264
Posted 11 July 2016 - 11:58 PM
Also fitted my bucket seats and harnesses back in, will have to modify the gear selector at some stage as its to far away
Edited by thelegg, 01 July 2017 - 09:26 PM.
#265
Posted 12 July 2016 - 03:46 AM
If it's like my shifter and has a bent in it you can disconnect it from the shifter rods and turn it 180 degrees and now the bend faces back....
Just beware it does change the position side to side very slightly which meant in mine it now contacted the side of the tunnel in 5th and reverse.
I ended up straightening the shifter, the ball is plastic so take it of before heating the stick up to bent it.
Also changing the position of the ball changes the distance of the throw aka a short shifter.
#266
Posted 12 July 2016 - 10:59 PM
#267
Posted 12 July 2016 - 11:10 PM
1st coat of resin
Did get a 2nd coat done as well :)
Edited by thelegg, 02 July 2017 - 11:19 AM.
#268
Posted 30 July 2016 - 09:17 AM
Also painted my rocker cover
Edited by thelegg, 02 July 2017 - 11:23 AM.
#269
Posted 30 July 2016 - 09:18 AM
#270
Posted 30 July 2016 - 09:34 AM
