Furry Micra Mini
324 replies to this topic
#241 thelegg
thelegg
  • 608 posts
Posted 09 April 2016 - 11:33 AM
Homemade frame so my drive shaft lengths won't be the same as your ones as your using an allspeed frame right ?
#242 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 09 April 2016 - 02:27 PM
No they won't best just to keep measuring it to get it as near spot in.
#243 thelegg
thelegg
  • 608 posts
Posted 11 April 2016 - 10:18 PM
Right then bout time I had a proper update, so I cut the jack plugs down and managed to plug them in all be it very snug
Next step, filled up with water only to find I'd left an outlet completely open so water pissed out everywhere haha blocked it off refilled it and had a small leak round the back, jubilee clip tightened and then onto the next step.
changed the oil n filter and also filled up the gearbox with fresh oil :)
Then the moment of truth I turned the key and she fired into life almost straight away :D
All the lights went out on the dash so I've obviously got oil pressure and the alternator is clearly charging :)
So now it's full speed ahead to get an MOT
Edited by thelegg, 02 July 2017 - 06:56 PM.
#244 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 12 April 2016 - 01:23 AM
Nice one, it's great hearing that sound means it has just got a whole lot closer to getting it on the road.
#245 lawrence
lawrence
  • 1,339 posts
Posted 12 April 2016 - 06:59 PM
It's so quite! My carbs are well noisy
Good luck for the mot
#246 thelegg
thelegg
  • 608 posts
Posted 12 April 2016 - 11:40 PM
Think that's just because I'm stood near the front lol if I went round the back n pressed the noisey pedal it would be loud ;)
#247 thelegg
thelegg
  • 608 posts
Posted 19 April 2016 - 10:23 PM
Well progress has been slow keep having to redo things I've already done :( just had to cut off and relocate the mounting points for my brake pipes at the side of my subframe as they were in the way of my shock absorbers, apart from that I've refitted my dash rails and my roll cage sorry not really anything worthy of pictures
Edited by thelegg, 19 April 2016 - 10:24 PM.
#248 'Chop'
'Chop'
    They don't call me chopper for nothing!!!
  • 543 posts
  • Local Club: 3 Custardeers Mini Club
Posted 20 April 2016 - 07:10 AM
This'll entertain Deano! He has fun enough with Chop at MOT!!
Keep up the good work :thumbsup:
#249 thelegg
thelegg
  • 608 posts
Posted 20 April 2016 - 09:03 AM
Cheers bud no idea when it will be ready for MOT lol
#250 thelegg
thelegg
  • 608 posts
Posted 22 April 2016 - 05:48 AM
OK so discovered that getting the mini wiper motor to work from the nissan wiring is beyond my electrical knowledge so I've decided to adapt the micra one to fit the mini, updates and pics to follow on Monday I hope lol
#251 thelegg
thelegg
  • 608 posts
Posted 22 April 2016 - 03:27 PM
Got rained off at work so had a few hours on the mini :) managed to sort my wiper motor issue,
Mini wiper motor
Attached File  20160422_121239_zpswpcr6dc4.jpg   56.39K   5 downloads
Micra wiper motor
Attached File  20160422_121201_zpsbb2p8y9g.jpg   55.59K   5 downloads
Dismantled both the motors and drilled out the mini casing so it fits over the micra spline, also had to grind the back down so it would sit flat. Next I shortened the micra spline and welded the mini drive cog to it
Attached File  20160422_134429_zpsotuqmhdx.jpg   55.1K   11 downloads
And half fitted on the car obviously need to attach it to the bulkhead somehow
Attached File  20160422_152811_zpsc9o3o7vq.jpg   57.97K   8 downloads
Next job will be fitting the front windscreen back in
Edited by thelegg, 02 July 2017 - 07:47 PM.
#252 lawrence
lawrence
  • 1,339 posts
Posted 24 April 2016 - 09:51 PM
Nice mod for the wiper motor. Does that mean the wipers will perform any better?
#253 thelegg
thelegg
  • 608 posts
Posted 25 April 2016 - 10:37 PM
Can't say till the screen is in and I fit the wiper arms but I guess they might be more reliable as it's a more modern motor :/
Totally can't get the front windscreen in so going to ring auto glass haha
#254 thelegg
thelegg
  • 608 posts
Posted 28 April 2016 - 11:06 PM
Windscreen bloke came out and fitted my screen today in like a blink of an eye haha then I decided to finish heat wrapping my exhaust so I opened my new heat wrap to find that the seller had added in a little gift :)
Attached File  20160428_194938_zps0imj2hvc.jpg   28.86K   8 downloads
Exhaust all done
Attached File  20160428_223304_zpsyvwtlbvg.jpg   39.76K   4 downloads
Started sorting out all the wiring for my front lights and indicators so hopefully get that finished next time I work on the mini
Edited by thelegg, 02 July 2017 - 07:55 PM.
#255 jackjewelljj
jackjewelljj
  • 241 posts
Posted 29 April 2016 - 09:25 PM
You stripping it all again for paint ect?
