Furry Micra Mini
324 replies to this topic
#226 thelegg
thelegg
  • 608 posts
Posted 09 March 2016 - 07:14 PM
Hi guys sorry for lack of updates, I've found the live wire for my fuel pump now and cleared all the scrap out of the micra so I could trace the wires back to the sender unit in the tank, turns out the yellow and green wire which I thought was low fuel light is actually the wire for the gauge however when I earth it out it doesn't move the gauge :(
Now then to add further confusion sometimes when I turn the ignition on the fuel gauge will go up to full and then about 5 seconds after the fuel pump relay clicks off the gauge goes back to empty ?????? Anyone got any ideas ????????
#227 EccentricToast
EccentricToast
  • 18 posts
Posted 09 March 2016 - 08:43 PM
Question are you trying to get the Micra loom to work with a set of mini clocks or going to adapt the Micra clocks to fit?
#228 thelegg
thelegg
  • 608 posts
Posted 09 March 2016 - 10:06 PM
Everything is micra so micra clocks with micra loom the only difference is I'm using the mini petrol tank not the micra one lol,
Really pee'd off with wiring now started connecting up rear lights only to find that my indicators and brake lights don't work and that the fog light comes on with the sidelights even tho its switched off! 😠
#229 thelegg
thelegg
  • 608 posts
Posted 13 March 2016 - 12:55 AM
Ok so have discovered that my micra even tho it's a 1999 car it has been wired like a 2000 model so now with new wiring diagrams I've managed to get most of the lights working except the indicators but I think this is due to there being no hazard switch, still can't get the fuel gauge to work but oh well. Wired in my electric fan too :)
Fitted my new speedo sensor sender thingy wow what a job haha couldn't do the bolt up once it was in so the grinder came out and now there's a hole in my floor....... Ooooops
Attached File  20160312_161210_zpspsevgwmc.jpg   57.81K   0 downloads
Edited by thelegg, 31 October 2017 - 04:46 PM.
#230 jackjewelljj
jackjewelljj
  • 241 posts
Posted 23 March 2016 - 05:09 PM
Any more progress?
#231 thelegg
thelegg
  • 608 posts
Posted 25 March 2016 - 02:42 PM
It's all gone abit slow at the moment but this turned up
Attached File  FB_IMG_1458837408812_zpsursgx4jn.jpg   35.32K   4 downloads
So hopefully get some more done over the weekend/Monday as I've got the day off, my drive shafts are almost finished so I'm going to trial fit them first before the final welding :)
All rear lights now work just need to fit a new brake light switch onto the pedal box
Edited by thelegg, 02 July 2017 - 08:28 PM.
#232 jackjewelljj
jackjewelljj
  • 241 posts
Posted 25 March 2016 - 04:23 PM
Looks good.
#233 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 28 March 2016 - 01:30 PM
inlets so nice cant wait to take my car up there this week soooo excited :P
#234 thelegg
thelegg
  • 608 posts
Posted 31 March 2016 - 10:40 PM
Fitted my inlet and connected up my fuel lines and relivent vacuum pipes :)
Won't be long before I can turn the key to see if she starts 😅 Also had to send my drive shafts back as they were slightly too long thank god they weren't welded yet haha
Edited by thelegg, 02 July 2017 - 09:24 PM.
#235 thelegg
thelegg
  • 608 posts
Posted 06 April 2016 - 10:57 PM
Right guys big problem, the jack plugs for my injectors don't fit and hit the plenum chamber on my inletmanifold :( has anyone else encountered this problem with a fusion fabrication manifold ? I have managed to squeeze injector plugs 1 and 2 on but 3 and 4 are a no go
PLEASE HELP !!!!!!
#236 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 06 April 2016 - 11:32 PM
Trimmed the plugs on mine slightly. Then just spent a bit of time to get them on! I would send a pic but their on not and I really done fancy pulling them off haha.
#237 thelegg
thelegg
  • 608 posts
Posted 07 April 2016 - 09:11 AM
Cheers mate I was about to start butchering the plugs so fingers crossed
#238 smudger068
smudger068
  • 344 posts
Posted 07 April 2016 - 09:38 AM
They were tight on mine and a right fiddle
if 1,2,3 go on and not 4 is your rail bolted on square?
#239 thelegg
thelegg
  • 608 posts
Posted 07 April 2016 - 05:32 PM
I'm having to plug them in before its bolted in as there's no room at all once it's bolted in place
#240 railtown
railtown
  • 35 posts
  • Local Club: mini7 club netherlands
Posted 08 April 2016 - 10:25 PM
Won't be long before I can turn the key to see if she starts Also had to send my drive shafts back as they were slightly too long thank god they weren't welded yet haha
drive shaft lengths  lengths are 319.00 and 590.00
