Furry Micra Mini
324 replies to this topic
#211 thelegg
thelegg
  • 608 posts
Posted 02 March 2016 - 06:59 PM
Right I've encountered a problem, can't find the full pump live in my loom or the wire that works the fuel gauge, has anyone got any idea what colour wire they are ?
#212 smudger068
smudger068
  • 344 posts
Posted 02 March 2016 - 07:09 PM
I have no nats loom I'm unsure if the colours are different but mine was
Black and Yellow for control switch to fuel pump relay. It went to black connector.
My ECU only turns I on for a few secs if the engine isn't fired. Then switches the pumps off
Edited by smudger068, 02 March 2016 - 07:10 PM.
#213 thelegg
thelegg
  • 608 posts
Posted 02 March 2016 - 07:28 PM
Where abouts is the black connector ?
#214 EccentricToast
EccentricToast
  • 18 posts
Posted 02 March 2016 - 10:59 PM
I have a 93 model might be different but won't be able to check until Friday evening for you though.
#215 thelegg
thelegg
  • 608 posts
Posted 02 March 2016 - 11:34 PM
Any help is much appreciated as the Haynes manual colours are completely different to my loom :(
#216 jackjewelljj
jackjewelljj
  • 241 posts
Posted 03 March 2016 - 06:30 PM
Can you not follow the wires from inertia cut off switch?
#217 thelegg
thelegg
  • 608 posts
Posted 03 March 2016 - 08:18 PM
Where's that to ? Lol
#218 smudger068
smudger068
  • 344 posts
Posted 03 March 2016 - 08:35 PM
https://www.micra.or...nats-jpg.17005/
Nats loom diagram if it helps at all unsure if its same as Haynes manual? if not I am stuck.
Maybe worth throwing some pics of what you have. Do you have the complete loom?
#219 thelegg
thelegg
  • 608 posts
Posted 03 March 2016 - 11:15 PM
It was a full loom to start with but I've stripped loads out I'll try get some pics next time I work on it, cheers for the diagram I'll have a look at it later, according to the Haynes manual it's a yellow n red wire that works the sender but this colour of wire doesn't exist in my loom lol
#220 EccentricToast
EccentricToast
  • 18 posts
Posted 05 March 2016 - 02:20 PM
These any use to you
#221 smudger068
smudger068
  • 344 posts
Posted 05 March 2016 - 05:37 PM
I see what you mean in the difference.
Black, Black/Red - Fuel Pump
Black and Red should go to the relay?
I will have to check the rest when I get back.
#222 smudger068
smudger068
  • 344 posts
Posted 05 March 2016 - 05:39 PM
Just seen on the board the fuel gauge sign. You can follow it back and buzz (multimeter) them to work out fuel gauge sender.
You could then work out most of the colours and what they do. process of elimination comes to mind using whats left to give you an answer
Edited by smudger068, 05 March 2016 - 05:40 PM.
#223 thelegg
thelegg
  • 608 posts
Posted 05 March 2016 - 05:42 PM
See that yellow and red wire is the one I'm missing it should work the gauge lol and the yellow n green wire is for the low fuel light I think, will be working on the mini tomorrow so if I have no luck I shall upload some pics of my wires
#224 EccentricToast
EccentricToast
  • 18 posts
Posted 05 March 2016 - 09:18 PM
Let me know if you need any more pictures
#225 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 05 March 2016 - 10:07 PM
On mine the fuel pump relay was switched on earth, the power was via brown wires and I think it was black and yellow going back to the ECU. This is for a pre facelift non NATS.
