Furry Micra Mini
324 replies to this topic
#181 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 08 February 2016 - 07:15 PM
Mines a daily. I'll take it out in light rain but anything a bit crazy or torrential is asking for it lol. 8mm I think the fuel lines are
#182 thelegg
thelegg
  • 608 posts
Posted 08 February 2016 - 07:33 PM
Cool cheers
#183 thelegg
thelegg
  • 608 posts
Posted 08 February 2016 - 07:38 PM
is that internal or external measurement ?
#184 Broomer
Broomer
  • 1,771 posts
Posted 08 February 2016 - 07:43 PM
Fair play on fitting the alt in under the exhaust but is that going to melt the plastic?
I remember my leccy fan was about that close and my exhaust melted the shiza out of it.
#185 thelegg
thelegg
  • 608 posts
Posted 08 February 2016 - 07:51 PM
It will be heat wrapped eventually, my choke cable used to rest on my heat wrapped exhaust on the A series and it never melted the plastic coating :/
#186 thelegg
thelegg
  • 608 posts
Posted 08 February 2016 - 09:13 PM
Slowly running out of things to do as waiting on parts to be delivered :(
Managed to fit the micra ignition switch and all the housings for the stalks onto the mini column.
Then returned home to find a big parcel :D
Next job will be plumbing it in
Edited by thelegg, 31 October 2017 - 04:27 PM.
#187 jackjewelljj
jackjewelljj
  • 241 posts
Posted 08 February 2016 - 09:29 PM
I've used 8mm copper lines for feed and return on k build
#188 lawrence
lawrence
  • 1,340 posts
Posted 08 February 2016 - 10:41 PM
If you need any heatwrap give me a bell. I've got some left from when I did mine. It's dead cheap stuff but works well, only issue is its colour fades from the heat. I think I've got just under a metre kicking around and some metal cable ties to hold it on.
#189 Shingler4596
Shingler4596
  • 221 posts
Posted 08 February 2016 - 11:19 PM
I can't heat wrap mine as two pipes are sitting to close together to fit it in between 😭 lol
#190 thelegg
thelegg
  • 608 posts
Posted 09 February 2016 - 12:51 AM
I can't heat wrap mine as two pipes are sitting to close together to fit it in between lol
can't you wrap them as one ?
#191 Shingler4596
Shingler4596
  • 221 posts
Posted 09 February 2016 - 10:24 AM
Possibly. I'm not sure if you can do that as I know heat wrap has to be done tidily so it doesn't direct heat to certain spots if you know what I mean
#192 EccentricToast
EccentricToast
  • 18 posts
Posted 09 February 2016 - 07:41 PM
How did you go about fitting the micra stalks and ignition barrel to the mini column?
#193 thelegg
thelegg
  • 608 posts
Posted 09 February 2016 - 08:29 PM
The stalks just screw into metal tabs that I welded onto the column exactly the same as they do in the micra, as for the ignition that was pretty much the same just weld on some tabs so you can bolt it on and I'm sure if you really wanted to you could line up the steering lock so that it works also but I couldn't be bothered lol
#194 thelegg
thelegg
  • 608 posts
Posted 10 February 2016 - 07:59 PM
Spent the evening syphoning out petrol and managed not to drink any for once haha soooooooooo old tank now removed :) also had lots of deliveries so shall be fitting my electric fan tomorrow :)
#195 thelegg
thelegg
  • 608 posts
Posted 11 February 2016 - 10:30 PM
Fan fitted
Also stripped my driveshafts down so there ready for measuring and then I can get them sent off to be sleeved and welded :) and I might of found someone to make me an inlet manifold :)
Edited by thelegg, 31 October 2017 - 04:30 PM.
