Furry Micra Mini
327 replies to this topic
#166 jackjewelljj
jackjewelljj
  • 241 posts
Posted 03 February 2016 - 10:05 PM
Well most idler pulleys just have metal bearings in them the same as cheap skateboard bearings, these are ceramic bearings which are even better than the metal type so in theory it should be fine I mean the wheel it's self is designed for riding on concrete etc so should be fine with a rubber belt on it
Ideal when you aiming for it to be on the road?
#167 Broomer
Broomer
  • 1,771 posts
Posted 03 February 2016 - 10:12 PM
Cereal packet is ok for mocking up brackets etc but you should prob use something more substantial for your alt bracket.
#168 thelegg
thelegg
  • 612 posts
Posted 03 February 2016 - 10:47 PM
May is the deadline
#169 thelegg
thelegg
  • 612 posts
Posted 03 February 2016 - 10:49 PM
Is 4mm plate not thick enough then ?
#170 thelegg
thelegg
  • 612 posts
Posted 03 February 2016 - 10:56 PM
Almost finished my exhaust, from this
To this
Alternator clearance
Just need to finish welding on the flanges and sort out where the sensor thingy will be going
Edited by thelegg, 31 October 2017 - 04:14 PM.
#171 thelegg
thelegg
  • 612 posts
Posted 08 February 2016 - 06:42 AM
Didn't get a lot done on Saturday as had to hurry home quick due to my road being underwater thanks to a river getting blocked up with a big metal roofing sheet so had to go for a paddle and unblock it lol. Anyway Sunday was better managed to finish my exhaust manifold :) then started on my radiator,
Decided the best route for the bottom hose was under the starter motor so made a metal pipe so that it won't rub through from touching anything.
Shorted the pipe on the engine so that it ends at the back and relocated the T piece
Fitted a mini thermostat housing to get a better angle
Also where does that other outlet in the picture above go to ? I'm guessing it's the return from the heater?
Refitted my steering column so that it's easier to move
Edited by thelegg, 31 October 2017 - 04:22 PM.
#172 lawrence
lawrence
  • 1,341 posts
Posted 08 February 2016 - 07:36 AM
Yep that pipe goes to the heater on mine. Nice idea with the water pipe. One of the other mini chaps on here has done that also, I'm thinking of redirecting mine that way. May borrow your idea for the rear engine mount also as mine seems to be too wobbly and killing driveshaft gaitors :(
Best of luck, bet you can start to see the end in sight by now too!
#173 thelegg
thelegg
  • 612 posts
Posted 08 February 2016 - 10:26 AM
Cool I'll just blank it off then as I don't have a heater lol, if you want any pics of my rear mount then give me a shout :) yeah slowly getting through the list of things to do !
#174 jackjewelljj
jackjewelljj
  • 241 posts
Posted 08 February 2016 - 11:14 AM
Put a heater in it! Hated mine with out it.
#175 lawrence
lawrence
  • 1,341 posts
Posted 08 February 2016 - 12:16 PM
I personally would keep the heater also :) but then again I use mine in the winter. I would appreciate a photo of the mount tho yes. Cheer bud
#176 thelegg
thelegg
  • 612 posts
Posted 08 February 2016 - 01:08 PM
But I never used to use the heater when it was fitted before hence why I'm removing it, ok bud I'll send you some pics in a personal message
#177 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 08 February 2016 - 01:29 PM
All I've removed from my heater is the ability to change it from hot to col ad the only time it will be one if it's too cold lol. If it's too warm open the windows :-)
#178 thelegg
thelegg
  • 612 posts
Posted 08 February 2016 - 04:19 PM
If it's cold enough to warent having the heater on then it's too cold for the mini to be out ;) lol
#179 Shingler4596
Shingler4596
  • 221 posts
Posted 08 February 2016 - 06:40 PM
Nah bugger that a mini should be used :-) if it's too wet then fair enough but cold nah ;-)
#180 thelegg
thelegg
  • 612 posts
Posted 08 February 2016 - 07:08 PM
lol yeah I drive mine as long as it's not wet although it was my daily for 3 years so it's done it's fair share of wet weather,
what diameter of pipe do I need for the fuel lines ?
    Bing (1)
