Furry Micra Mini
324 replies to this topic
#136 thelegg
thelegg
  • 608 posts
Posted 20 January 2016 - 10:03 PM
Round nose, got a carbonfibre front end sat in my garage at home :) I do like clubmans and have always wanted one tho
#137 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 21 January 2016 - 06:44 PM
2 inches seems.like a more space than there should be unless I'm just thinking wrong because my hi-los at the lowest ride very close to the bump stops. I had to cut them down so I had good travel.
#138 jackjewelljj
jackjewelljj
  • 241 posts
Posted 21 January 2016 - 06:58 PM
Something must be wrong, you seem to have a lot of ground clearance, my frame wasn't as low as yours and I had less ground clearance
#139 thelegg
thelegg
  • 608 posts
Posted 21 January 2016 - 11:12 PM
Dunno lol it's a mini there's never 2 alike ;)
Anyway updates although nothing major, started work on my clutch by making a spreader plate which bolts to the bulkhead
And then welded on some fixings for my brake hoses
Edited by thelegg, 31 October 2017 - 03:13 PM.
#140 thelegg
thelegg
  • 608 posts
Posted 23 January 2016 - 08:37 PM
Today started with pumping flood water out of the pit lol
Then I finished off my clutch pedal although I'm not getting enough travel so will have to alter it again
Then I modified a DSN classics billet alloy blanking plate so that it would block off the clutch side but keep the brake side open
More updates tomorrow :)
Edited by thelegg, 31 October 2017 - 03:20 PM.
#141 666junky
666junky
  • 1,225 posts
Posted 24 January 2016 - 10:34 AM
Careful with the clutch cable mount, even with a large plate on the bulkhead i still found i had alot of flex in the shell when pressing the pedal. We sorted it by making a blanking plate like yours but welding it to the clutch cable spreader plate.. kinda like a triangle shape if that makes sence. Just a heads up :)
#142 l_jonez
l_jonez
  • 1,453 posts
Posted 24 January 2016 - 10:48 AM
Yep you will get a fair bit of flex. I braced mine heavily
#143 thelegg
thelegg
  • 608 posts
Posted 24 January 2016 - 10:55 AM
Don't have any flex at the moment, the spreader plate sits over like the little recess that's in the bulkhead which has given it more strength plus it's very close to the cross member but if I do notice it flex I shall alter it, on a side note the original bracket that holds the cable onto the engine does flex when pushing the pedal :S
#144 Shingler4596
Shingler4596
  • 221 posts
Posted 24 January 2016 - 06:51 PM
Have you tried the pedal properly in the car then checked for flex? The bulk head is thin and I can't imagine there being no flex at all but maybe that's just me!
#145 thelegg
thelegg
  • 608 posts
Posted 24 January 2016 - 09:41 PM
I've altered the pedal and I've now got plenty of travel, I've been working the pedal with my grandad watching the bulkhead and he said its not really flexing so I feel quite happy with my setup
#146 thelegg
thelegg
  • 608 posts
Posted 24 January 2016 - 11:31 PM
Shortened my gear selector thing
Also modified the back of it where it attached to the car so that now it sits lower :)
38013055806_3ab0af6911_n.jpg[/ur
And it fits on the car lovely and selects all gears perfectly
The spanner slipped off whilst I was doing it up and I whacked myself straight on the nose so now I've got a nice little cut and I feel like a right idiot haha
Looks ok inside may adjust it slightly once my seat is back in
Also brought my front end up to to work shop which almost fits just needs a little trim here n there :)
[url=https://flic.kr/p/ZV5Sew]38013059496_d5ff02371d_n.jpg
Edited by thelegg, 31 October 2017 - 03:33 PM.
#147 thelegg
thelegg
  • 608 posts
Posted 26 January 2016 - 11:32 PM
It fits :) bit too much gap on the passenger side between the wing n bonnet but sure abit of fetling later on will sort it :) ignore the wonky grill lol it's only on with 1 screw
Had a little play with some radiators quickly and will have to side mount the mini rad I think as not enough room to front mount one but I think I'll just be able to squeeze my alternator in the front but it's gonna be tight!
Edited by thelegg, 31 October 2017 - 03:35 PM.
#148 thelegg
thelegg
  • 608 posts
Posted 28 January 2016 - 11:28 PM
Got my alternator fitted ended up using the original micra one in the end :)
Had to grind the block away so I could sit it in close
Bracket finished
Tight but it does clear
Edited by thelegg, 31 October 2017 - 03:39 PM.
#149 lawrence
lawrence
  • 1,340 posts
Posted 29 January 2016 - 01:01 AM
Looks great bud. Make sure you sort the charging circuit before you run her for long. I wired mine in for a test to make sure all the pulleys etc were lined up nicely and fried the circuits in it :( so had to get another!
#150 thelegg
thelegg
  • 608 posts
Posted 29 January 2016 - 06:20 AM
Won't it just be a case of plugging it in seeing as it's the original alternator for the engine? Or do I need to change something ?
