Oil Leak
Posted 26 October 2015 - 02:30 PM
1275 A+ engine.
Would this be the primary gear oil seal,and is it doable with engine in situ?
Posted 26 October 2015 - 02:33 PM
Posted 26 October 2015 - 03:35 PM
Have a look under the clutch housing. There is (should be ) a pin hanging down. Is there oil dripping from this? If so, it is a possible sign of the seal failing.
Your oil could well be coming from a leak higher up though....possibly from the valve cover or dipstick tube.
I'd clean the engine well and go for a run...then have a look and see if there is fresh oil leaking from the clean engine
Posted 26 October 2015 - 11:53 PM
Does your clutch slip?
Don't think it is,but have noticed last week or so,revs are staying up a bit.Was thinking this may just be the accelerator cable sticking tho.
Posted 26 October 2015 - 11:55 PM
There is oil on this pin,but I did wipe it all down previously and I'm confident its coming from the starter bolt and running down.
Posted 27 October 2015 - 02:33 PM
Unless the leak is outside the bellhousing and tracking down....which would be nice!
Posted 27 October 2015 - 05:57 PM
That would be very unusual...read unlikely
If that is the case i will take another look again.Cheers
Posted 03 November 2015 - 10:52 AM
I am wondering if the timing side is just where it's ran across to here from clutch side.
Also noticed a bit of oil,around the dizzy.Can it leak here? It's clamped down tight tho.
Cheers in advance,just cannot gather where it's coming from,except this starter bolt hole...
Posted 03 November 2015 - 02:50 PM
I'd still be suspect of the valve cover gasket leaking and possibly the dipstick.
You have crankcase ventilation from the clutch cover or timing chain cover? Is it plugged?
Posted 03 November 2015 - 05:41 PM
Rocker cover gasket seems fine,no leaks as I renewed this a few months ago. Dipstick is no longer leaking,fitted new o- rings and its tight in the hole in block now also. I have both ventilated and running to the carb.
Posted 16 December 2015 - 11:52 PM
So my next question,is it possible to do it while engine in car and any special tools needed or a how too or tips on here?
Posted 17 December 2015 - 04:11 AM
It is possible to do with the engine in situ, but can be a bear.
You'll need to release the engine mount on the clutch side, and release the top engine steady from the block.
Raise the engine a little with a jack on the clutch side of the gearbox.
Remove the clutch return spring… ( if a verto I'm not sure how it works )
Now you need to scrape some skin off undoing all the bolts holding the clutch cover on ( nine I think ). The rear most lower two are the worst.
You'll need to remove the starter and have something to lock the ring gear while you put some brute force into undoing the flywheel bolt.
Someone else can take over from here…lol…off to bed.
Bottom line….much easier to do with the lump out of the car
Posted 17 December 2015 - 05:03 AM
Posted 17 December 2015 - 12:33 PM
Posted 17 December 2015 - 02:14 PM
I did this many years ago, engine in the car and without the proper tool and it was a right pain...
It will be much more manageable with this device: https://goo.gl/zdCyur
The 13H2934MS seal from Minispares seems to be well regarded and isn't exactly expensive.
...and as Dusky alludes to, much easier with the bonnet off.
Edited by Matt's Dad, 17 December 2015 - 02:16 PM.
