Wow. I bet that was an amazing feeling seeing it looking like a car again. I bet you cant wait to crack on with it now.
Holy Crap! 1275Gt Resto
#556
Posted 12 September 2018 - 06:59 PM
#557
Posted 12 September 2018 - 07:26 PM
I don't get enough GT time, but it's slowly taking shape now. I can see another big order from Minispares heading my wayWow. I bet that was an amazing feeling seeing it looking like a car again. I bet you cant wait to crack on with it now.
#558
Posted 16 September 2018 - 06:46 AM
Had a couple of hours on the GT this afternoon, so this is what was in the box
A solid subframe mount kit from minispares. Check out the manly cups
Got the subframe on then had a go at lining the front end up
So that's where we left it, it's a mile out at the mo but a day fettling will sort it out, almost looks like a car again
Hey check this out looks ace with its front end back in place mate, nice work!
#559
Posted 16 September 2018 - 03:30 PM
If I'm ever going to get this car done in time for the IMM I'll need to get an hour in the garage every day... so todays hour was cleaning the front shock mounts of all the crud, rust and paint, and they're now soaking in white vinegar to get rid of what's left of the rust
I'll leave them in for a few days then get em etch primed and painted
#560
Posted 16 September 2018 - 09:03 PM
#561
Posted 16 September 2018 - 09:28 PM
I think it's my only hope mate, little and oftenNice one mate. I try and do a bit a night too, it’s the only way.
#562
Posted 16 September 2018 - 09:36 PM
#563
Posted 17 September 2018 - 05:38 AM
An hour a day and you will be for sure mate...
#564
Posted 17 September 2018 - 08:25 AM
#565
Posted 17 September 2018 - 08:20 PM
We got the solid mounts initially for lining up the front end, but one of the original bulkhead rubber mounts had split apart. I'll run with the solid mounts and see how they goAre you planning on running with the solid subframe mounts or did you just get these to Sid alignment of the front panels?
#566
Posted 18 September 2018 - 09:38 AM
Deffo recommend solids Jimmy, dont notice any difference in noise, but alot better steering. Had them on H7 for 8 years, only fitted them to Firecat this year, and wow, wondered why i'd not done it before. Also helps stop flex on the front end, ie cracking on the seams at the front.
#567
Posted 18 September 2018 - 11:06 AM
#568
Posted 18 September 2018 - 12:31 PM
Doesn't parts of the floor need reinforcing to run solid mounts ??
#569
Posted 18 September 2018 - 02:01 PM
Ideally yes, they say the toe board cracks under stress. I welded some 2.5mm steel plates on the inside on mine to spread the load.
#570
Posted 18 September 2018 - 02:03 PM
Bing (2)
