Holy Crap! 1275Gt Resto
945 replies to this topic
#391 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 25 September 2017 - 10:30 AM
Hi,
i'm replacing my boot floor too and i'm about at the same stage as you are.
does anyone know how to get the rear subframe mount area at the correct height ? does it involve using the two holes on the rear wheel arch lip ? there must be a way to get it spot on. If one side is slightly higher then the car won't sit straight.
Pete.
Hiya Pete, can I just say I'm making this build up as I go along. I'll be using the old subframe, minus the arms for weight saving, to line it all up.
Have a look at Sonikk's project paddy, he's probably covered it on there with lots of photos
Good luck with it, Jim
#392 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 25 September 2017 - 04:24 PM
Gutted. Seat belt bolt on the inner sill was a bit tight so thought I'd try to tap it out, and the feckin nut has snapped off on the inside of the sill. Looks like I'll have to sacrifice the outer sill.
Balls!!!
#393 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 11 October 2017 - 04:52 PM
Had a few hours on the GT today despite a heavy dose of man flu, we all know that's the worst possible illness haha. Thought I'd have a crack at getting the boot floor in
So it's sort of in, I need to weld in the passenger side arch and strengthening brackets and then it's on to the rear valance and closeouts. Thanks to R kid for dragging me into the garage.
Now where's me lemsip...
#394 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 19 October 2017 - 07:04 PM
Got the passenger arch in today, I think the next day in the garage will be dressing a lot of welds back, God knows how many plug welds I've done putting the boot floor in, my neighbours will hate me haha
I'm running out of panels now, looks like I'll be ordering the front end soon
#395 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 October 2017 - 09:35 AM
You're making good progress on this. It shall soon be a lovely GT shell again.
#396 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 30 October 2017 - 01:32 PM
loads of progress there, that shell is really taking shape now
#397 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 30 October 2017 - 03:41 PM
Thanks mate. Not sure it's the right shape though haha
#398 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 30 October 2017 - 05:38 PM
Nice one. Just noticed Minispares are having a sale on Heritage panels. Saved £165, that's the bonnet paid for
#399 slidehammer
slidehammer
  • 1,214 posts
  • Local Club: LSMOC
Posted 30 October 2017 - 08:22 PM
Really starting to take shape now, a real moral boost seeing all that nice rust free steel going in, keep up the good work.
#400 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 06 November 2017 - 07:03 PM
Magnum panels eh? Pile of crap haha. Had a right faff trying to get the valance and closeouts to fit snugly, had to drill the spot welds off the closing panels and do a cut and shut. Got there in the end, then realised I had to weld a piece on to complete the closing face.
My main issue is this, tried to old subframe in place to see if the bolt holes lined up, the trunnion sits about 12 or 13mm too high ( or low if it's the right way up ) and fouls on the wheel well. I don't remember there being spacers when we dropped the frame. Can't work out why? It's the same on both sides, the floor position is governed by the base of the rear panel and the bottom rear of the quarter panels?
Any advice would be much appreciated, Thanks
#401 Homersimpson
Homersimpson
  • 851 posts
Posted 06 November 2017 - 07:17 PM
There are supposed to be some strengthening panels welded to the underside of the bootfloor which I think might be part of the rear valance closers.
This will help but won't take up a 13mm gap and you need some space between the sub-frame and the body as it will move being rubber mounted and the last thing you want are squeeks and bangs.
#402 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 November 2017 - 07:20 PM
So is the frame hard up against the boot floor?
At a guess, I would say that the floor is too low in relation to the heel board but it's hard to tell without seeing it properly.
I really hope that isn't the problem...
#403 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 06 November 2017 - 07:55 PM
There are strengthening panels incorporated in the closeouts, but as you say they won't make that gap up
#404 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 06 November 2017 - 08:17 PM
It fouls on the wheel well, ie the back part of the frame between the rearmost trunnions, nowhere else. The frame was bolted to the heelboard.
I've taken the trunnions off the old frame so will fit them on the new one and try that, the old frame had been jacked on that part of the frame that's fouling and is slightly mis shapen, but not enough to cause this issue I think
#405 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,021 posts
Posted 06 November 2017 - 10:06 PM
Hope this is easy for you to get sorted mate. Following with interest as usual.  :thumbsup:
    Bing (1)
