Hi all,
I'm new to this forum and found it while trying to find out which ECU might be used in my SPI.
My current ECU is the MNE101150. It is a coded one but the mobilizer is disabled by some dummy box.
Now according to my garage, the ECU is behaving badly as
- it does not control the stepper motor any more
- the fuel pump keeps running as soon as ignition is turned on (without motor running)
- the fuel pump keeps running for about 15 seconds after turning the ignition off again.
I would prefer to use an uncoded ECU to prevent the hassle of re-programming anything. I found some threads about the MNE101050 which seems to be uncoded but from the information I find, this is for the Rover 114 and not a Mini SPI. I did also find the MNE101070 which is uncoded as well but for the (64hp) Cooper model.
Now my questions:
- Do the above symptoms actually indicate an ECU problem?
- Can I use the MNE101050 and/or MNE101070 to replace my MNE101150?
- Are there other alternatives?
Thanks for your help
