Slam Panel Numbered Plate
19 replies to this topic
#1 limby2000
limby2000
  • 366 posts
Posted 18 October 2015 - 10:38 AM
Hi having put a new front end on my roundnose a while back now. There was a small plate that seemed spot welded to the slam panel, just right of centre. I chopped off this piece in case it was of any significance and maybe reattatching if it was needed. My car is a 89 mini thirty made then by rover, and has the rover vin plate rivetted on the drivers side inner wing. Any idea?
#2 limby2000
limby2000
  • 366 posts
Posted 18 October 2015 - 10:41 AM
Forgot to mention it has reverse embossed numbers.
#3 chuffed
chuffed
  • 131 posts
Posted 18 October 2015 - 11:15 AM
I'm pretty sure that is an identity number. (Same as a chassis number on a modern car!)
There ahould be a similar number on the scuttle gutter
#4 sledgehammer
sledgehammer
  • 3,096 posts
Posted 18 October 2015 - 12:26 PM
Tack it back on
It should be the chassis number
the more Id you can preserve on the car , the better
it is also sometimes on the scuttle (as above) , but on a 89 , this has probably long gone
there is also an commission plate on the slam panel - sometimes - but the corrosion gets to the rivits
Edited by sledgehammer, 19 October 2015 - 08:49 PM.
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,014 posts
  • Name: Neil
Posted 18 October 2015 - 12:46 PM
Does it look anything like this
If so it a panel number.
#6 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 18 October 2015 - 12:58 PM
Numbers stamped in the floor might be customs references for imported cars... Our van resto had one, now cut out & kept, for when it was imported into Norway; the SPi was imported from Germany, so has one as well. Keep it, in case!
#7 1984mini25
1984mini25
  • 8,784 posts
Posted 18 October 2015 - 01:06 PM
The number on the slam panel is nothing more than a factory reference body number, it has nothing to do with the stamped in chassis number in the scuttle, or the riveted chassis plate. Personally I'd keep it for originality and without it makes it more oblivious the front panel has been replaced. Although mine was removed when I replaced the front end and due to one end being slightly rotten, I've lost half of one of the numbers and it seams no one uses reverse stamps anymore to get a new one made up.
ps. there's also a few beers to anyone who can reverse stamp some numbers into a strip of steel...
Edited by 1984mini25, 18 October 2015 - 01:23 PM.
#8 Keith Staley
Keith Staley
  • 83 posts
Posted 18 October 2015 - 01:20 PM
I agree with tacking it back on for originality
Edited by Keith Staley, 18 October 2015 - 01:20 PM.
#9 limby2000
limby2000
  • 366 posts
Posted 18 October 2015 - 01:30 PM
Yep, i agree, will refit before painting, it is made from very thin metal though, may have to use epoxy. Thanks guy,s.
#10 sledgehammer
sledgehammer
  • 3,096 posts
Posted 18 October 2015 - 02:36 PM
on my 1989 mayfair , it is the chassis number , it is like a dyno label for .5 mm steel strip
on a 1989 there should also be a commission number
Edited by sledgehammer, 19 October 2015 - 08:48 PM.
#11 limby2000
limby2000
  • 366 posts
Posted 18 October 2015 - 04:48 PM
I think your right sledgehammer,it is a small strip of ultrathin tin. Will check against v5.
#12 sledgehammer
sledgehammer
  • 3,096 posts
Posted 18 October 2015 - 05:41 PM
now I'm wondering how thin the steel would have to be to go thru this ?
http://www.ebay.co.u...egAAOSweW5VTt1B
#13 limby2000
limby2000
  • 366 posts
Posted 19 October 2015 - 02:08 PM
Have checked against v5, and there is no number like this!.
#14 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 19 October 2015 - 04:58 PM
The above is is correct.
I'd put it back on as it shows some care and attention to detail has been taken when working on the car - all to often these are simply thrown away.
#15 sledgehammer
sledgehammer
  • 3,096 posts
Posted 19 October 2015 - 08:48 PM
Looks like I was wrong - can't find mine , but could have sworn it was part of the chassis number
where the **** have I put that ???
In the safe place - with all the other missing stuff
