Clutch Slave Cylinder Removal
Best Answer David128 , 19 October 2015 - 01:59 PM
Removal of the Verto slave cylinder is usually straightforward .2 ways of doing it
1. Remove the 2 bolts either side of slave cylinder and lift off.
2. remove to rear bracket mounting boltss and the single front bolt below slave cylinder push rod.
Go to the full post
9 replies to this topic
#1 Big Sam
Big Sam
  • 853 posts
Posted 17 October 2015 - 05:30 PM
After many years of neglectful mini ownership i've started stripping the bugger.
I've been following a guide which appears here:
http://www.theminifo...engine-removal/
and im doing alright, but I can't get to the nut nearest to the bulkhead on the clutch slave cylinder. I've done a couple of searches on here and on google and to no avail (I may just be rubbish at searching). Is there a technique that might require a crash course in yoga or preferably a socket extension doo daa thing that will make it a bit actually possible to remove?
Cheers!
#2 Spider
  • 14,838 posts
Posted 17 October 2015 - 06:54 PM
A couple of ways you can tackle that one (Pre-verto?)
I find a 3/8" Drive 9/16" Socket gets in there.
Or leave it until last, after the engine steadies and exhaust have been disconnected, then you can usually tilt the engine quite a bit forward and you'll get at it with a ring spanner.
#3 Big Sam
Big Sam
  • 853 posts
Posted 17 October 2015 - 09:09 PM
Yeah, pre-verto sorry for neglecting that bit of info!
Ah genius, never actually thought about how freely the engine will move with the steadies removed (well duh!), i'll give that a shot tomorrow then,
I can get my sockets on but they are right up close to the pipe so i can't get any of my wrenches or angle joints into it to get it out.
#4 nicklouse
  • 18,576 posts
Posted 17 October 2015 - 11:38 PM
A spanner works as well.
But it does depend on what else you have in the way. A U J also works
#5 Big Sam
Big Sam
  • 853 posts
Posted 18 October 2015 - 06:05 PM
Engine steadies and exhaust are both detached, engine moves forward less than an inch, still can't get at the bugger. Might need to invest in some short spanners unless someone has any other ideas?
#6 Big Sam
Big Sam
  • 853 posts
Posted 18 October 2015 - 06:48 PM
Turns out I was wrong, i was informed a while back it was pre verto and blindly believed it to be the case, from googling it seems it is actually verto:
Now I imagine that changes any possible removal procedure?
#7 Spider
  • 14,838 posts
Posted 18 October 2015 - 06:57 PM
Yes. Sorry, I haven't done one of them.
#8 Big Sam
Big Sam
  • 853 posts
Posted 18 October 2015 - 07:03 PM
Not problem thanks for your help though.
#9 David128
David128
  • 644 posts
Posted 19 October 2015 - 01:59 PM   Best Answer
#10 Big Sam
Big Sam
  • 853 posts
Posted 19 October 2015 - 06:29 PM
Method number 2 worked like a charm, couldn't get to the bolt on the other side for method 1 but a trust 7/16 spanner sorted out single front bolt which completely passed me by and it came straight off. Cheers!
