What Spares Do You Carry?
16 replies to this topic
#1 Batmini
Batmini
  • 378 posts
Posted 16 October 2015 - 07:07 PM
Having rescued a fellow mini owner on the way to the Malvern mini show last weekend with the loan of a coil, just wondering what most on here carry as spares?
I maybe paranoid but here's my list:
Plugs
HT leads
Coil
Fuses
Cable ties
Insulation tape
Spare wire
Spanners, cutters, pliers and screwdrivers
#2 Minimattvan
Minimattvan
  • 105 posts
Posted 16 October 2015 - 07:11 PM
Sounds like a pretty good mini- "first aid kit" ! Mines not on the road yet, but was thinking along the same lines- never know when or what u might need!
#3 Rocket.
Rocket.
  • 1,441 posts
Posted 16 October 2015 - 07:16 PM
My AA card is all I need
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 October 2015 - 07:17 PM
Above +
Fanbelt
Rotor Arm
Spare Electronic Ignition Kit
Distributor Cap
Jumper Wires with Croc Clip Ends
Spare Multimeter
Electronic Fuel Pump
2 x 4 Terminal Relays
Mini Maglight
2ft 1/4 bore fuel pipe and clips
#5 CityEPete
CityEPete
  • 3,920 posts
Posted 16 October 2015 - 10:15 PM
All the above and a classic car weekly to read :-)
#6 New game mini
New game mini
  • 294 posts
Posted 17 October 2015 - 09:44 AM
None of the above +
Tow rope
My phone
My Dads number
Starting to think I should put together a first aid kit 😏
#7 lawrence
lawrence
  • 1,340 posts
Posted 17 October 2015 - 03:26 PM
Quite a few bits for me now I think about it.
Spare easy fit aux belt, litre of oil. 500mls pre mixed coolent. Few wiring terminals and crimp tool. Pokey type 12power tester. Spanner set. Screwdriver set. Allan key set. Socket set. Scissor jack. Locking wheel nut and wheel wrench. Exhaust clamp. 10high strength heat resistant cable ties. One of each bulb that may blow. Hid bulb and spare ballast. 3x kneeling carpet pieces. Disposable gloves. Block of wood for jacking on uneven surfaces. Reflective waterproof coat. Tyre pump and instant tyre seal stuff. Oh and a gallon size fuel tank for spare fuel!
I also do the occasional drill should something go wrong and know I have enought tools to fix anything that is repairable by the side of the road!
+have a friend with a trailer for last resort
It actually looks fairly tidy!
So that's all my spares haha
#8 mikal
mikal
  • 240 posts
Posted 17 October 2015 - 11:21 PM
Because my road trip was from Melbourne Australia to Bali, Indonesia I took a few a few extra items with me:
Front wheel bearing kit
2 oil filters
Fuel filter
spare fuel hose
Tie wire and 12V wire/connectors
Exhaust mounts
Remote housing mount
radiator hoses
fanbelts
Selection of bolts etc
Spare plugs and ignition stuff. Coil, points etc
Fuel pump
Fuses
Light globes
Flywheel puller
Tool box
Fire extinguisher
500mL of concentrated Octane booster
So far (touch wood!) I've only used plugs (2 just failed on separate times), condenser (one failed and car ran like a dog, took me a while to work that one out ) filters and Octane booster (Some parts of Eastern Indonesia only low octane fuel available)
#9 Dusky
Dusky
  • 5,322 posts
Posted 18 October 2015 - 10:27 AM
I carry nothing but a fanbelt and tools
For daily use its not needed imho, she s pretty well totaly overhauled so nothing should break the comming 10 years :)
#10 smurfomatic
smurfomatic
  • 460 posts
Posted 18 October 2015 - 12:26 PM
In terms of spares, only a fanbelt, an old but serviceable set of plugs and some bulbs & fuses. Broken down in it a few times in the last five years, but mostly situations where carrying spares would make no difference - clutch failure a case in point! Electrical issues were a major problem for the first year or so, causing it to cut out at speed on one occasion.
Prepared for most things by carrying spare oil, water and petrol alongside the tools: spanner and socket set, screwdrivers & pliers, hammer, multimeter, torch, jack & wheel chocks.
#11 1984mini25
1984mini25
  • 8,784 posts
Posted 18 October 2015 - 12:44 PM
My tool kit for the past 10 years with no extra breakdown cover has been...
Scissor jack, breaker bar, 11/16" socket and locking wheel nut, foldable wheel chock, cheap spanner and socket set, screwdrivers, pliers, hammer, a few random fuses, bulbs, screws and bolts, cable ties, Insulation tape, spare wire, small bottle of water, kitchen roll and plasters.
#12 surfblue
surfblue
  • 1,827 posts
Posted 18 October 2015 - 07:45 PM
Credit card
Mobile phone
Sense of humour
#13 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 18 October 2015 - 08:38 PM
Damn you guys - you fuel consumption and performance must be rubbish with all these tools and spares you carry! If it's well maintained then it shouldn't break down!
Which ever car I'm driving (either the mini, ford galaxy or transit) I always just make sure I have phone and AA card! want to keep the weight down and put all the horses under the bonnet to good use!
#14 Batmini
Batmini
  • 378 posts
Posted 18 October 2015 - 08:54 PM
I don't have the patience to have to wait an hour(or more!) for someone to then not know how to fix it :) I prefer to sort it and be on my way. I do regularly maintain mine, but every component can fail at some time. The guy i helped had spent plenty of money maintaining his car, but the coil still failed. I'm over a 100kg, so a couple more for some spares wont matter lol!
#15 spiguy
spiguy
  • 1,537 posts
Posted 18 October 2015 - 09:16 PM
I used to carry all sorts of parts. Have now narrowed it down a bit to :
Fuses
Some wire
Radiator cap (have come unstuck before with one!)
Fan belt
cable ties
Couple of plug leads
Rotor arm
Dizzy cap
Pint of oil
Litre of coolant
Small bottle of brake fluid
Crank sensor *
Throttle position sensor*
Vacuum pipes*
*The car is an SPi, and these are items that if they fail will either completely stop the car from running (crank sensor) or make it undriveable or barely driveable (vac lines and throttle pot respectively).
Touch wood, I have only ever needed a Rad cap, and at that it was only really an issue as I was on a long run. If I had been local or not too far away, could have limped it home with the leaking one.
Hope I haven't jinxed myself now, but in truth over the years my minis have been rock solid reliable. Sure, there have been clunks, odd behaviours, things not quite right, but my minis have basically been able to get me from A to B reliably. This is actually one of those areas that contrary to alot of peoples opinions, old cars triumph in.
I actually think that in real terms, old cars which are well maintained, and where the owners know the car and know their way around it, are more reliable than many modern cars, which with the slightest fail of a sensor / coil pack etc can end up at the roadside. Even though I have an injection car (single point) I would still say it is more reliable than most modern cars.
