Crankshaft Endfloat
28 replies to this topic
#1 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 12 October 2015 - 09:20 PM
I fitted the crank to the block tonight at the start of my engine rebuild, all went well until I checked the end float which I measured at 10 thou. What thrust washers do I need to buy to reduce the figure and what is an exceptable endfloat.
Andy.
#2 Swift_General
Swift_General
  • 871 posts
Posted 12 October 2015 - 09:40 PM
10 thou is a bit on the big side. Aim for around 3 thou, certainly no less than 2 thou. You don't say what washers you have at the moment. Oversize are +3 or +30 thou (the +30 needs to be machined down). If they are new STD washers then a set of +3s either side would bring you endfloat down to about 4 thou which would work fine, but obviously service life would be a bit less than with a lower figure. If you are using used STD washers then you may already have some wear so even just fitting new STD washers would bring the endfloat down.
#3 Spider
  • 14,838 posts
Posted 13 October 2015 - 12:17 AM
yeah, 0.010" is a bit on the high side for a roadie.
I run with 0.004 to 0.006".    0.003" is to tight I've found (and yes, I know what the book says).
Fitting the +0.003's will get you to 0.007", which I feel is still too high, though you'd get away with it.
Your best option here is to get a set of +0.030" thrusts and have them ground.
#4 andyt
andyt
  • 375 posts
Posted 13 October 2015 - 05:00 AM
They are standard size at the moment, from the 70,000 mile engine before rebuild.
#5 Cooperman
  • 23,276 posts
Posted 13 October 2015 - 09:23 AM
If you fit +0.003" on both sides you will reduce the float by 0.006" and that, at 0.004" float, will be ideal.
#6 Spider
  • 14,838 posts
Posted 13 October 2015 - 10:09 AM
What Thrust Washers can you guys get? Seems they are 0.003" per side (0.006") in total.
The ACL ones I use are 0.003" in total.  Would be handy to get some like you guys get a hold of.
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 13 October 2015 - 10:50 AM
So they are already worn?
Minispares sell standard, .003 and .030.
#8 andyt
andyt
  • 375 posts
Posted 13 October 2015 - 04:29 PM
Thanks for the replies, minispares has 003 though ones listed but they only mention 1275 and not 998 is there a difference.
Andy.
#9 carbon
carbon
  • 2,590 posts
Posted 13 October 2015 - 04:37 PM
1275 and 998/1098 use same crank thrust washers.
850s use smaller crank thrust washers
#10 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 13 October 2015 - 04:40 PM
Did you measure it on worn thrusts?
#11 andyt
andyt
  • 375 posts
Posted 13 October 2015 - 07:17 PM
Yes I did,10 thou on originals from 70,000 mile engine.
#12 Spider
  • 14,838 posts
Posted 13 October 2015 - 07:30 PM
Ah, OK, you should find some new STD Thrusts and measure again.
#13 andyt
andyt
  • 375 posts
Posted 13 October 2015 - 07:45 PM
Oh should i just buy new standard thrusts or the +003 thou ones?
Andy.
#14 Cooperman
  • 23,276 posts
Posted 13 October 2015 - 07:57 PM
They are so cheap you could get a set of standard and a set of +0.003", then you can 'mix & match' until you get the float within limits. Or measure the thickness of the ones you took out and someone on here will tell you the thickness of standard ones. remember, the pair nearest the clutch end will have most of the wear and the ones on the timing chain side will be virtually unworn.
#15 Spider
  • 14,838 posts
Posted 13 October 2015 - 07:58 PM
It can be a bit of a pain. Normally you'd buy STD Thrusts, fit them and measure again. Then if the end float is outside of spec. and going to the next size will bring it within spec, then buy another set, next size up. Why it's a bit of a pain is that you'll possibly end up with a set of STD washers as the supplier is under no obligation to take them back. They are not expensive though.
If you know a friendly engine builder, they may lend you a set of each, or buy your unused STD washers from you, if you find you are stuck with them.
<Edit: Cooperman's suggestion is a better one, he was quicker on the keys than me!>
Edited by Moke Spider, 13 October 2015 - 08:00 PM.
    Bing (1)
