Starting The Micra Conversion
147 replies to this topic
#16 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 22 November 2015 - 05:19 PM
Ok loom is probably 90% done. And it works... Thankfully.... and it started for the first time!!
https://youtu.be/d04wxtIbFkY
As stated in the video there's no exhaust on it and it runs a bit rough because the vacuum lines aren't connected properly but the main thing is our loom works!!!
Edited by Shingler4596, 22 November 2015 - 07:33 PM.
#17 thelegg
thelegg
  • 608 posts
Posted 22 November 2015 - 08:42 PM
How much of the micra loom have you kept ?
#18 Shingler4596
Shingler4596
  • 221 posts
Posted 22 November 2015 - 09:14 PM
Not a lot at all... pretty much just the bare minimum to get it to run. But I had a non-Nats micra which made things a lot easier.
#19 SamFoster
SamFoster
  • 46 posts
Posted 23 November 2015 - 10:00 AM
what year micra needs to be bought to avoid the nats? your conversion is flying mate, spot on!
#20 Shingler4596
Shingler4596
  • 221 posts
Posted 23 November 2015 - 11:58 AM
I bought a 1994 one myself. Not 100% sure when they introduced it. I'd keep 1996 and below of possible although nats isn't impossible to work around :-)
#21 thelegg
thelegg
  • 608 posts
Posted 23 November 2015 - 05:40 PM
As far as I'm aware NATS 1 can be bypassed but NATS 2 can not, well not easily anyway. Not sure what year the different systems got introduced but I've got a 98 micra which has got NATS 2
#22 SamFoster
SamFoster
  • 46 posts
Posted 24 November 2015 - 09:20 AM
cheers lads, will try and find one as early as possible. What sort of mileages have the engines got that you both are putting in? Are you rebulding them prior to dropping them in or your not really bothered about that?
#23 Shingler4596
Shingler4596
  • 221 posts
Posted 24 November 2015 - 12:00 PM
Mine had 70k is I think but it runs so sweet and quiet. They really are great engines. I won't bother recycling. I'll do some new gaskets but that's about it really :-)
#24 thelegg
thelegg
  • 608 posts
Posted 24 November 2015 - 01:35 PM
29k full service history and runs sweet I will probs port n polish the head a bit
#25 thelegg
thelegg
  • 608 posts
#26 Shingler4596
Shingler4596
  • 221 posts
Posted 01 December 2015 - 08:34 PM
Ok so have an exhaust manifold made up and fits in well its not the prettiest of sights and probably doesn't have the best flow (still probably better than the standard) but it will get the car on the road long enough for me to save and get longlife to make one for me out of stainless. Cooling probably the next job... still lots to do. Also got the throttle cable mounted so it works of the mini cable which makes things easier. Clutch cable will have to wait until engine is back out at its in the way. Hoping to have all this done so I can make the trip to japfest next year... also may start future proofing for a turbo... 😉
Edited by Shingler4596, 01 December 2015 - 08:35 PM.
#27 thelegg
thelegg
  • 608 posts
Posted 01 December 2015 - 09:49 PM
Pics ? Turbo is always the way forward ;)
#28 Shingler4596
Shingler4596
  • 221 posts
Posted 01 December 2015 - 10:06 PM
As I said not the best looking but it will get the car quiet until I can get one done by the local longlife. I'll get a picture of the throttle setup once its back on.
#29 thelegg
thelegg
  • 608 posts
Posted 01 December 2015 - 10:35 PM
Looks good :)
#30 Shingler4596
Shingler4596
  • 221 posts
Posted 04 December 2015 - 05:12 PM
So there's the full manifold. Lines up really nice at the bottom and have found a good place for the lambda. Just waiting on v-band clamps to finish it off.
