Starting The Micra Conversion
#136
Posted 20 May 2016 - 07:18 PM
I was getting 45-50mpg with the ITB's
#137
Posted 20 May 2016 - 07:31 PM
#138
Posted 20 May 2016 - 08:02 PM
#139
Posted 20 May 2016 - 08:45 PM
#140
Posted 21 May 2016 - 07:56 AM
I also have a 1.3 Micra, in standard form (870kg) and can say top end acceleration is poor, but what do you expect for 75bhp. From about 80mph acceleration is pretty slow. The higher the speed, the more drag, hence you need more power.
What power do you think your running?
I'm surprised your comments about the gear ratios. They look spot on, on paper, with expection to maybe 1st is a little short with the 3.895 Final drive. I'm considering putting the 3.895 crownwheel & pinion into the facelift 1998 - 2000 998 box, to create a closer ratio box, ie
1275 V 998
3.331st. 3.062 1st
1.955 2nd 1.826 2nd
1.286 3rd 1.207 3rd
0.927 4th 0.902 4th
0.756 5th 0.756 5th
#141
Posted 21 May 2016 - 08:15 AM
Compared to 3.895 box
100mph at 5000pm & 120mph @ 6000rpm
All based on 175-50-13
#142
Posted 21 May 2016 - 08:37 AM
There very little difference between the 998 and 1275 box in 1st gear terms, as the gear ratio and Final drive cancel each other out to a degree. Both are going to wheel spin.
Again, the 998 box with 1275 FD may be the answer.
#143
Posted 21 May 2016 - 02:05 PM
The Micra can pull 100mph at a push. So I'm sure the Mini would be able to pull 90-100mph no problem, bearing in mind the mini is not the most aerodynamic.
CdA of Micra is 6.89
CdA of mini is 8.415
Strangely enough (I thought it would be better) the Modern VW Beetle is 8.64 apparently.
CdA takes into account drag co-efficient and frontal area
It's all academic anyway my mini isn't going to be going that quick even if it could.
#144
Posted 04 July 2016 - 03:30 PM
#145
Posted 05 July 2016 - 04:30 AM
Cars been on the dyno today. Considering it's pretty standard, only inlet and exhaust it got 103bhp at the flywheel and 83 at the wheels... plenty of potential left... mmmmmmmmmmm turbo................
Nice, sounds like a similar output to mine...
Do you have a dyno graph? what RPMs did it achieve peak hp? Torque figures?
I'm considering cams for mine, but I'm a little afraid the Green Cotton filter which is supposed to top out at around 100hp / 110hp is the bottleneck. Legally I must have a covered air filter (ie in some sort of box) for noise regulations.
I'll have to talk to Matt Humphries to see what they have got the filters etc up to...
#146
Posted 05 July 2016 - 10:38 AM
#147
Posted 07 July 2016 - 10:23 AM
Posted 17 July 2016 - 09:52 PM
Great conversion Shingler, impressive work. Just got myself a Micra to do the same but don't think I'll get mine done as quickly as you.
Edited by Mike_Y, 17 July 2016 - 10:10 PM.
