Just thought I would share a few pictures of my Mini Pickup restore -
Some of the rusty floor and X member:
RUSTY TUNNEL.jpg 62.4K
6 downloads
RUSTY TUNNEL 2.jpg 70.04K
4 downloads
RUSTY X.jpg 37.98K
3 downloads
RUSTY INNER SILL.jpg 50.7K
3 downloads
RUSTY INNER WING.jpg 92.57K
9 downloads
On the spit ready to remove the floor:
ON THE SPIT.jpg 60.31K
10 downloads
SPIT.jpg 53.53K
5 downloads
I welded in some bracing to help hold it all together:
BRACING.jpg 49.25K
6 downloads
BRACING 2.jpg 45.07K
6 downloads
I bought loads of new panels from Mini Machine:
NEW PANELS.jpg 76.32K
19 downloads
Removed drivers side and part of the tunnel:
FLOOR REMOVED 3.jpg 66.86K
8 downloads
FLOOR REMOVED 2.jpg 56.63K
5 downloads
FLOOR REMOVED.jpg 74.12K
5 downloads
TUNNEL REMOVED.jpg 80.51K
6 downloads
TUNNEL REMOVED 2.jpg 60.55K
4 downloads
and replaced the part of tunnel with new bits from the new tunnel:
TUNNEL WELDED IN.jpg 58.3K
10 downloads
and then replaced the drivers floor:
FLOOR CLAMPED IN.jpg 51.23K
4 downloads
FLOOR CLAMPED INSIDE_n.jpg 52.33K
6 downloads
FLOOR CLAMPED.jpg 50.32K
4 downloads
Then welded it all in and done the same with the passengers side where I found the rear subframe mount was rusty:
RUSTY SUBFRAME MOUNT.jpg 90.03K
7 downloads
So I made up a new part to weld in using the original mounting nuts and bracket, and welded it in place:
SUBFRAME MOUNT.jpg 44.96K
7 downloads
NEW SUBFRAME MOUNT.jpg 40.73K
4 downloads
I replaced the X member and replaced the original handbrake mounting bracket:
HANDBRAKE.jpg 53.64K
7 downloads
After a little bit of tiding, I sprayed the bottom of the floor with epoxy mastic primer (great stuff by the way):
FINISHED.jpg 53.82K
19 downloads
Obviously the work continues but the floor is a bit better than it was! Next I need to move forward and do the inner wings, inner A panels, etc.
More pictures can be found on www.facebook.com/MyMiniPickup. And I will try to update this also.
Enjoy!
Any comments/advice/help would be welcomed.
Edited by myminipickup, 07 October 2015 - 04:30 PM.
