Posted 07 October 2015 - 07:16 AM
So I don't know if somewhere down the line these wires meet up but they have all miraculously stopped working. So does anyone know what could be the problem, or where to check?
Posted 07 October 2015 - 07:42 AM
They'll all be on the second fuse down only live when the ignition is on (think).
Posted 07 October 2015 - 10:13 AM
You mean heater motor? Heater matrix I'd full of water
Yeah that's what I mean
Posted 07 October 2015 - 10:18 AM
Check the back of the fuse box for corrosion
Posted 08 October 2015 - 10:42 AM
If it turns out the fusebox is ok then check for a feed in and out on the terminals, and when your satified that you have voltage there, then its time to move to checking the connections at the wiper motor (FAQs has a post showing terminals) and check for a feed into the stalk and out when the flash is pulled.
circuit is below
Edited by KernowCooper, 08 October 2015 - 10:43 AM.
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
