Rear Wheel Bearing Removal
Best Answer Stevie W , 04 October 2015 - 04:13 PM
Hi,
There are 2 outer races that are an interference fit inside the hubs. With both inner races (bearings) and the rear oil seal removed, proceed as follows:
Clean any excess grease from inside the hub and locate the raised ring cast into the middle of the hub. There should be two notches approximately opposite each other. Support the hub to stop it tipping over, then use an appropriate sized drift to tap the outer races out towards the hub edges.
They can be a little stubborn, but judicious tapping should see them come out eventually!
Hope this helps!
Cheers, Steve.
Go to the full post
Posted 04 October 2015 - 02:26 PM
Posted 04 October 2015 - 02:40 PM
Posted 04 October 2015 - 04:13 PM Best Answer
Hi,
Hope this helps!
Cheers, Steve.
Posted 04 October 2015 - 04:26 PM
Posted 04 October 2015 - 04:28 PM
Posted 04 October 2015 - 04:29 PM
Posted 04 October 2015 - 07:32 PM
Hi,
Hope this helps!
Cheers, Steve.
That's how to do it. Just use a soft drift, brass or aluminium, so you don't damage the hub.
Posted 06 October 2015 - 06:12 PM
