Hi all
I have bought these
http://www.minisport...s-set-of-4.html
They have a 28 stage damper settings, can I have some suggestions on settings (how many clicks front & rear ?)
Many thanks
Kevin
Posted 02 October 2015 - 10:03 PM
Hi all
I have bought these
Many thanks
Kevin
Posted 03 October 2015 - 07:54 AM
Assuming your Min is on the road and not the track, then as a starting point put the fronts at 12 ( 1 being full hard) and the rears at 18 ( nearing full soft). Then adjust for comfort versus handling bearing in mind that the front suspension does most of the work and the rear just follows.
For track use the fronts would be towards 1 and the rears 12 with adjustments made to suit driving style.
Edited by rww, 03 October 2015 - 07:56 AM.
Posted 03 October 2015 - 08:34 AM
Fully anti clockwise is it's softest setting, and as above, start of about 1/2 way on the front and about 1/4 way on the back...
Posted 03 October 2015 - 05:52 PM
Thanks for the info
I have set the fronts to 14 and the rears 7.
We shall see how that goes.
