Hi all
I have bought a new padded lower dash rail trim from MiniSpares, together with the chrome trim strip and clips, for a 1981 Mini.
Any advice on how this should be fitted in detail?
It looks like the dash trim is just glued in place. Any thoughts on a suitable adhesive?
Then under the dash rail, the trim is just cut to size to make things tidy. There are no clips.
On top of the dash rail, the trim is cut back level with the rear edge of the dash rail?
Push the clips on to the back of the dash rail, over the rail and glued on dash trim. With the raised bump on one side of the clip is on top.
Tap the chrome trim on to the clips. Having tried a clip in the trim, tap is probably not the right word, more bash.
Once done can the chrome trim and dash trim ever be removed, without being damaged in the process?
Dave
