Mill Road Garage, Isle Of Wight. Classic Car Restoration Services
580 replies to this topic
#121 sledgehammer
sledgehammer
  • 3,132 posts
Posted 03 June 2018 - 10:12 AM
love the attention to detail
nice to see someone taking the time to get it right with the repairs
hate to say - most so called 'restorers' are just in it for a quick buck - or rushing to the deadline
also it does amaze me when a customer is rushing a workshop for a restoration to be completed
fantastic work
#122 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 June 2018 - 08:06 PM
I have been cracking on with the Mini 40 the past few days. I have only just gotten round to sharing the progress with you though.
I have spent quite a while playing around with the door gaps on the n/s door. They were very far out as you could see in the last update. I knew the car had previously had a quarter panel and so this was suspect despite the fact it's also had an A panel.
I had to start somewhere so I concentrated on getting the front gap and the window frame as good as possible.
It's a little tighter at the bottom but If I shim it across a bit, then it is far too tight at the back
So this is where I settled
Then back off for prep and primer
All important riv-nuts for the mirrors
Then a seal up
Then back to the booth
Along with the bonnet which had some damage
Repaired, primed and prepped
And then paint.
I knew this car has been painted at least 3 times so I wasn't going to assume that the colour code on the VIN would produce an accurate match so I had it scanned and the closest match was a Citroen colour so I went with that.
Ill paint the other bits on the car on Thursday!
Ben
#123 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 05 June 2018 - 09:25 PM
Awesome work Ben, Charlotte is one extremely happy girl!
#124 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 June 2018 - 09:55 PM
Good stuff :-)
#125 MikeRotherham
MikeRotherham
  • 1,031 posts
Posted 06 June 2018 - 07:33 AM
Hi Ben,
A couple of questions:
When you are wrapping a door skin around a the door framework could you use a car panel adhesive as they seem to do when building modern cars now? It may help to keep the seam rust free or do you think it unnecessary?
When you are welding two flanges/surfaces together e.g. spot welding an outer sill to the door step or plug welding the outer sill to the inner sill. Do you prime/paint the inner surfaces then just bare metal the two contacting surfaces then weld or use weld thru primer?
Mike.
#126 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 June 2018 - 05:11 PM
Hi Ben,
Mike.
You can use an adhesive between the frame and the skin before wrapping but it makes a mess and you have to work quickly to get the skin folded, onto the car and then adjust the skin if necessary before welding, all before the sealer goes off.
And then when you weld the skin, the sealer often gets in the way making a mess again.
I prefer to fully coat the frame and the skin, fold the skin, weld and then seal the skin to the frame after to keep wet out and then flood the inside with wax.
As for welding on panels, I tend to leave the e-coat if it is sound as this is good at keeping rust away. I clean back the weld edges and coat with zinc before spot welding
Ben
#127 Homersimpson
Homersimpson
  • 851 posts
Posted 06 June 2018 - 07:30 PM
Personally I wouldn't seal the skins on as I have had bad experiences (twice) using polyurethane type sealants and the welding the edges up to get gaps.
Something strange seems to happen to the sealant where you get it hot and the sealant makes the seams rust very quickly,  I now have to reskin four doors on a car where rust is breaking through the new skins after less than 2 years.
I cant believe it but this is the second time this has happened to me,
#128 MikeRotherham
MikeRotherham
  • 1,031 posts
Posted 07 June 2018 - 06:34 AM
Thanks for the info.
#129 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 June 2018 - 05:30 PM
I've been beavering away with the prep.
Nothing exciting so I shan't bore you all with the details.
I drove it into the booth, masked up and primed some minor repair areas
Despite my best efforts, there just wasn't enough time to paint today so whilst the primer hardened, I polished the bonnet and doors instead.
Ill paint the car in the morning and then it can go back together!
Ben
Edited by Ben_O, 07 June 2018 - 05:32 PM.
#130 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 June 2018 - 06:22 PM
I painted the Car this morning
And then this turned up after lunch for some paintwork
I don't usually post up about my other jobs but when was the last time anyone saw one of these?!
It only needed some minor work so I spent a few hours sorting that
And then back to the Mini.
I started fitting the parts back on
Door on
The new rubbers have thrown the door gaps out again so they will need time to settle in
Ben
#131 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 June 2018 - 05:40 PM
Almost rebuilt now.
New guides on the windows
Anti drum
New moisture barrier
One side finished
I refitted the bonnet and the other door which is now 99% built up.
Just a de-nib and polish on the drivers side, stick on the decals and done.
Ben
#132 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 11 June 2018 - 07:40 PM
Spectacular attention to detail as always Ben!
#133 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 June 2018 - 04:44 PM
Well the 40 is now finished.
#134 wingnut
wingnut
  • 468 posts
Posted 13 June 2018 - 05:45 PM
Fab
#135 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 June 2018 - 06:14 PM
It is one of my favorite LE Mini's and really is a credit to it's owner.
There is something about a White Mini with Chrome that I really like. It just looks right
    Bing (1)
