Mill Road Garage, Isle Of Wight. Classic Car Restoration Services
580 replies to this topic
#331 Crazy
Crazy
  • 274 posts
Posted 23 February 2020 - 06:41 PM
What an excellent thread, just gone from page 1 to hear, fantastic work Ben, Do you have an email I could fire over some photo's to and some information I am looking for some work to be done.
#332 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 February 2020 - 12:13 AM
Hi.
Thanks for taking the time to read the thread and for your interest.
I would be pleased to take a look at the work you require and you can send photographs and information to me at millroadgarage@outlook.com
Ben
#333 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2020 - 04:40 PM
I have been cracking on with the Neon.
There was a hole in the o/s/r floor pan. Nothing major so I just patched it up
Ill replace the anti drum at paint time to cover the repair
Next up was the 1st of the arch tubs.
I started by cutting off the old one so that I could see what repairs were required in the surrounding panels.
It was all pretty nasty so will require some patching before the arch tub can go in.
First up was this hole
And then I cut and replaced some of the floor return where it had become thin and holed
Here is some of the worst of it cut out
and another hole to repair all cut out ready for patching
And patched
And then once the rest of the tidying was done, the new tub was welded in
There was also another hole lurking behind filler
Which got cleaned up, patched up and a repair piece was made up ready to weld in
More tomorrow
#334 kit352
kit352
  • 256 posts
Posted 25 February 2020 - 09:26 PM
That passenger side rear tub was my biggest worry other than the scuttle area. It was very poorly repaired before so i knew it was hiding things. Of course i didnt think it was that severe but now i dont need to worry about it. Hopefully the other side is more straight forward.
#335 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2020 - 09:38 PM
The passenger rear tub was very bad. The rust beneath the plate that had been welded on had spread into the plate so would soon have weakened significantly so best that it's done now.
I think the other side will be straightforward as straight away it is visibly much better.
If all goes to plan, I'll have the other side finished tomorrow too and it all sealed up/stonechipped and then the subframe can go back in on thursday.
Cheers Ben
#336 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 25 February 2020 - 09:48 PM
My mini is in this thread, the blue MK2 S (around page 15 I think).  Really happy with the work, proud to be part of Ben's work on this thread : :D
#337 Crazy
Crazy
  • 274 posts
Posted 25 February 2020 - 11:32 PM
Hi.
Ben
Sent a mail over Ben
#338 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2020 - 10:20 AM
Hi.
Ben
Would you mind double checking the address please? Only I haven't received anything from you.
Ben
#339 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 February 2020 - 12:09 PM
I have now finished the last of the welding on the neon
Passenger side was finished off first
And then I began the drivers side
#340 kit352
kit352
  • 256 posts
Posted 27 February 2020 - 02:09 PM
That looks like a much better area to work in than the other side.
#341 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 February 2020 - 04:10 PM
All sealed up
And then stonechipped
Both rear radius arms were heavily worn and had lots of play in them so I picked up a set of exchange units
Which I built up onto the frame
I ran a new front to rear brake pipe as the old one was shot and now the frame is ready to go back in but not until the morning as the stonechip is still not dry
Then ill set about respraying the car as the current finish is pretty poor
That and the fact the lacquer flies off in sheets like sunburn if you go anywhere near it with an air blower :lol:
#342 kit352
kit352
  • 256 posts
Posted 28 February 2020 - 07:09 PM
Painters tape is also a quick way to remove the clear coat :)
#343 Crazy
Crazy
  • 274 posts
Posted 01 March 2020 - 05:26 PM
Hi.
Ben
Ben
Did just copy and paste it, Have just tried to send it again from another account though.
#344 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 March 2020 - 12:48 PM
I have refitted the subframe to the Neon and its now rolling once again
And then onto the body prep..
The quarter panels were fairly wobbly from previous repairs to them and had a fair amount of filler in them.
I need to level everything out before painting so the first step is to apply some medium body filler to the low area around the arches
The stuff I use is very good as it works a bit like self levelling floor screed and actually flows and settles. Its called Evercoat Rage Ultra for anyone interested and its great for the initial fill.
Once rubbed back, further coats are applied and rubbed down to create the rough level and shape like so
The dark area by the arch radius is guidecoat showing that this area is still low.
A further coat rectifies that
Before a coat of fine stopper to sort any pin holes or minor low spots
It seems like a lot of filler but by the time its rubbed down at each stage it's only minimal.
I've already finished the other side
And prepped the roof
Besides the prep, I investigated the carburettor. The car was running very rich and was smoking quite a bit with all the unburnt fuel.
I stripped it down
Besides some gumming and some bits floating around, it's all in good order.
I believe the running issue was caused by the needle which had far too much slop so new parts were ordered.
I also called in a favour and had the parts ultrasonically cleaned
And then serviced and reassembled
More to come
Ben
#345 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 11 March 2020 - 01:30 PM
Great work Ben, and it's good information for anyone carrying out repairs to there mini.
    Bing (3)
