Thanks Paul.
I shall be in contact before I go much further to discuss a few things.
It's all going well so far though!
Ben
Posted 15 October 2018 - 07:31 PM
Thanks Paul.
Ben
Posted 19 October 2018 - 02:00 PM
I have finished tidying up the lower flitches.
One side straightened and the welds tidies up further
Then after a through clean up and a light skim it's ready for prep
I stripped the filler from the other side
and then tidied up the welds and dressed out the low spots and distortion
And then a light skim finishes this side too
I shall come back to the flitches at prep time to re-seal and stonechip.
Ben
Posted 19 October 2018 - 03:22 PM
One of the things I had been asked to do to the Cooper is re-pin and bush the hinges on the drivers door.
There was a fair amount of slop, particularly in the bottom hinge.
First thing is to remove the hinges
I stripped the bottom hinge first and found a lot of wear on the pin
After drifting the old bronze bush out, I drifted the new one in followed by a new pin
And did the same with the top hinge
The pin was fine but the bush was worn through
Here it is all assembled back to the door and tried onto the car
Another job done
Posted 19 October 2018 - 03:28 PM
This episode brought to you by HP
Posted 19 October 2018 - 06:40 PM
Fantastic Ben, thank you. Love the improvements so far.
Posted 19 October 2018 - 08:06 PM
..top marks for getting the hinges off without any of the studs shearing !!
Posted 23 October 2018 - 10:27 AM
New Mirrors!
First, I mark the position of the adaptor plate. This is designed to screw to the standard mirror points of later cars which this does not have
Drill
Install riv-nuts
Attach adaptor and seal
Followed by the mirror
And the other side too
Next up, remove the rear seatbelts and strip the paint from inside the boot!
Posted 23 October 2018 - 11:27 AM
Posted 23 October 2018 - 02:15 PM
I have started on the boot now
I just need to clean it back far enough to see what needs repairing and then the rest can be done once the repairs have been made
The boot board brackets and one tank stand had been rivetted on so I removed those
And then stripped the paint back. There were several layers and the latest coat had been applied without any prep so it was flaking off
There are a few holes to sort out as well as some straightening out
Ben
Posted 23 October 2018 - 03:22 PM
The patch of filler on the turret was hiding nothing more than a rough plate which although ugly, is sound
Ill tidy that up
The back edge where previous repairs had been made was quite badly distorted and the welds hadn't been tidied very nicely.
I have started to straighten it out and tidy things up
George seems to be enjoying the dust and paint peelings. Just look at that dumb smile on his face
Posted 23 October 2018 - 03:52 PM
More corrosion beneath the stiffener.
Ill need to cut that whole section of floor out and replace it
Posted 23 October 2018 - 05:28 PM
Looks like I was right to get you to sort it out So looking foward to a tidy boot
Posted 23 October 2018 - 06:44 PM
Charles seems quite happy as well
Posted 23 October 2018 - 07:45 PM
Ha ha. We have a George too so I must have got mixed up!
Posted 26 October 2018 - 03:28 PM
Few more repairs on the 'S'
Ben
