Alternator Upgrade
19 replies to this topic
#16 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 30 September 2015 - 01:06 PM
Its also worth considering the charging cable between the alternator and the starter solenoid. Over time the cabling deteriorates and resistance builds up and less current reaches the battery.
I produce new cabling capable of 76A so covers all bases and has noted an improved charge rate on my own 45A alternator with halogen upgrades, amp and four spot lights.
I also recommend that after a run with headlights, heater etc on to let the car idle with everything turned off to allow the battery to re-charge.
#17 Brams96
Brams96
  • 2,308 posts
Posted 01 October 2015 - 06:01 PM
What size cable do you use. 4 awg?
#18 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 01 October 2015 - 07:49 PM
I don't go by awg sizes. I use two cables rated at 38A giving ample charging capacity.
I'm happy to sell the components, but for another £10 I'll make it for you!
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 October 2015 - 09:11 PM
I use 2 x 6.0mm 84/0.30mm Thin Wall Cable @50amps
#20 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 02 October 2015 - 09:13 AM
As above, i use 2 x 4.0mm 56/0.30mm Thin Wall Cable @38A - but either will be an improvement on old thick cored wiring
