Why You Should Keep Your Standard Air Box
Posted 27 September 2015 - 11:23 PM
Posted 28 September 2015 - 05:54 AM
My SPI is running a lot better with the K&N element V the 57i induction kit! Generally speaking but pulling through the gears is smoother and there's more power at the top end!
It's ok if you like the noise but I've just turned the stereo up instead.
Posted 28 September 2015 - 07:28 AM
I have often wondered that. I have the new Cooper 'S' MPI kit and it uses the K&N filter. I don't like the look of it, or the sucking noise it makes. I may go back to the standard bo (also with a K&N) and see if it makes any difference.
I did have it on the rolling road and the kit with the K&N filter on the top has given me 84BHP & 96Lbs torque
Q
Posted 28 September 2015 - 08:17 AM
Edited by Steve220, 28 September 2015 - 08:18 AM.
Posted 28 September 2015 - 09:57 AM
To be honest since a mini isn't the most streamlined design, plenty air will be being forced through the front grill and around the engine. (Less so in an MPi for reasons of the radiator).
I swapped my K & N cone for a filter box with K & N internal filter, because I was fed up with the induction roar. Car drives better and anyway you can mod the standard box to flow better
FS
Edited by FlyingScot, 28 September 2015 - 09:59 AM.
Posted 28 September 2015 - 11:34 AM
Air Cooler ducts, just think what does a normal carb filter do. Can assure you with the ITG kit and air ducts you notice the difference vs the airbox.
And as for the induction roar.. ;wub: how can you not love it?
Posted 28 September 2015 - 02:07 PM
The standard air box has a pick up for hot air from the manifold, its not uncommon for them to jam open and you are always picking hot air from below.
The only actual problem of KN cone vs standard air box, is the poor design of the cone which requires (a very simple) modification to stay 'solid' in place and to stop it falling off every then and now.
Induction noise is a personal preference, some may love it, some hate it.
Posted 28 September 2015 - 03:22 PM
In the SPi, yes. MPi is a different/better design.
Posted 01 November 2015 - 12:05 AM
ITG or RAMAIR foam filters with baseplates work just fine. Cone filters or mesh covered filters run hotter as the metal gets hot. JCG used ITG successfully, I used RAMAIR with a ram pipe, all good.
Posted 01 November 2015 - 07:33 AM
Posted 01 November 2015 - 12:07 PM
agreed! I think that the best thing to do for injection cars at the minute is to use the K&N filter that fits in the standard air box - these filters flow far better than standard filters, this is by having larger holes in the filter, but they have lots of little whiskers that catch the muck that gets through, similar to how nose hairs work! (ewww) this should manage to get any cooler air available into the engine and with the benefits of a free flowing filter? correct if I'm wrong on any of this!How come no one makes a desent enclosed type filter/housing? Surely there's enough minis of the newer type (spi/mpi) to make it worth while.
Posted 01 November 2015 - 02:51 PM
Isn't David Vizard amazing?!
Posted 01 November 2015 - 02:58 PM
Visard is amazing ;) - but he did recommend cone filters...
