Hi guys!
So my car finaly runs ( with good oil pressure, yay!)
ANyway, I bought a lightened pre verto clutch , backing plate and diafragm along with a slave cylinder etc ( basically everything to convert from pre verto to verto) .
Now, when I push the clutch the car almost stalls, but even worse : the clutch doesn't disengage enough to get into gear.
The crank endfloat and primary gear endfloat is fine( I've checked that with my dti) .
My best bet is in the clutch release bearing doing something wrong, as it does make a bit of a grinding noise when pushing the pedal.
Anything on these pics seems awkward?
And could I run without the return spring? I adjusted the clutch according to this article :http://www.7ent.com/...adjustment.html
cheers
