Rubber Versus Spring?
26 replies to this topic
#1 Jools33
Jools33
  • Just Joined
  • 56 posts
Posted 27 September 2015 - 03:56 PM
Okay, I am refurbing my rear subframe along with the rest of the pickup. What is the consensus of opinion regarding replacing the "doughnut" with springs?
I saw these at the Stanford hall event.
Do they improve the suspension & if so in what way?
Cheers.
#2 nicklouse
  • 18,562 posts
Posted 27 September 2015 - 04:04 PM
They don't improve anything.
They replace a rising rate Spring with a linear rate Spring.
So as you add load to the car it just gets lower and lower. It does not do what the original does, get stiffer to accommodate the load.
A bad design just there to remove money from people's pockets.
Edited by nicklouse, 27 September 2015 - 04:04 PM.
#3 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 27 September 2015 - 04:09 PM
:highfive:  Can't improve perfection. The rubber doughnut is a perfect design for the classic mini. :shades: It's basically a progressive stiff spring. :kiss:
#4 Jools33
Jools33
  • Just Joined
  • 56 posts
Posted 27 September 2015 - 04:47 PM
Thanks, looks like I'll stick with the tried & tested.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 September 2015 - 04:48 PM
Not sure what there refering to but my suspension kit uses progressive springs, like the kit on Minispares, no issues at all with mine and the ride is not as bouncy
#6 hhhh
hhhh
  • 422 posts
Posted 27 September 2015 - 05:40 PM
Wouldn't bounciness be solely determined by damping rather than spring rate or other spring characteristics?
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 27 September 2015 - 06:24 PM
I've got them fitted to mine, but it's got no engine :(.
Interesting though Dave, what dampers are you running?
#8 FlyingScot
FlyingScot
  • 2,664 posts
Posted 27 September 2015 - 06:31 PM
Got blue minitastic type on my Japanese import. It's a little less direct than with doughnuts but better over rough roads.
FS
#9 limby2000
limby2000
  • 366 posts
Posted 27 September 2015 - 07:05 PM
I've got minitastic fast roads on mine, there great. You do need adjustable dampers to get the best out of them. Better over pot holes!
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 September 2015 - 09:06 PM
Gaz adjustible ones on mine, the damper is to control the spring though, so it does affect the ride quality
#11 nicklouse
  • 18,562 posts
Posted 27 September 2015 - 09:22 PM
I am yet to see any progressive springs for the Mini other than the rubber ones.
Got a link. I might be interested for my rears.
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 September 2015 - 09:32 PM
These are listed as profressive Nick http://www.minispare...|Back to search
#13 Tupers
Tupers
  • 4,142 posts
Posted 27 September 2015 - 09:34 PM
Minitastic springs are supposed to be progressive because they're tapered. Clicky
I'm sure if you put them on a spring dyno they'd act very differently to a rubber cone through. There simply isn't enough room in a Mini for a proper rising rate coil without some serious body and suspension mods.
#14 Spider
  • 14,821 posts
Posted 27 September 2015 - 09:37 PM
One thing I found (on test) with all springs out there, including the Minitastic ones (sorry guys) is that they don't have enough compression height before spring bind, not an issue if the height is set lower than stock, but don't set them over standard height.
I'm a fan of the idea, but I haven't come across any yet that are a direct replacement for the rubber cone.
#15 nicklouse
  • 18,562 posts
Posted 27 September 2015 - 09:45 PM
The minitastic ones still look like plain gauge springs just with a different space between the coils. That ain't a progressive Spring. Still linear.
To be progresive the cross section of the wire needs to change.
Air is a great progresive Spring medium and that can be easily be controlled and calibrated.
Edited by nicklouse, 27 September 2015 - 09:47 PM.
