Engine Breather Pipe
6 replies to this topic
#1 Denver
Denver
  • 33 posts
Posted 20 September 2015 - 06:32 PM
I've noticed my breather pipe is hanging loose behind the rad and the carb connection point is blanked off with a dust cap, it passed its MOT 2 weeks ago, it runs ok. Is this a problem or should I leave it?
#2 jpw1275
jpw1275
  • 2,803 posts
Posted 20 September 2015 - 06:59 PM
If it's not broke don't fix it !!
Cheers james
#3 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 20 September 2015 - 07:22 PM
Must admit I like the dust cap. I'd whack a hose clip on the hose though?
#4 Spider
  • 14,843 posts
Posted 20 September 2015 - 07:27 PM
I'd reconnect it, your oil seals will work marginally better.
#5 Wim Fournier
Wim Fournier
  • 177 posts
Posted 20 September 2015 - 07:37 PM
And, don't forget that the burned gasses that pass between the piston and cilinder wall (blow by) have quite a lot of water damp in them that mix up  with your engine oil to form nice black mayonaise in the rocker box. When you disconnect the positive crankcase ventilation a lot more water remains in your engine block. Do you remeber the white smoke coming out of the exhaust pipe when you start up in a freezing morning. That is water damp. In the summer there is even so much water in the exhaust, even when you don't see it because it is not condensing in the open air.
#6 Denver
Denver
  • 33 posts
Posted 20 September 2015 - 07:56 PM
The other end is connected to the Oil Separator? or is it the crank case breather canister?
I don't like it loose just hanging behind the rad,does it need a jubilee clip to connect to the carb?
Ive just noticed one of these on minispares.... would this be better than plugging it back in the carb?
http://www.minispare...11.aspx|Back to
Edited by Denver, 20 September 2015 - 08:07 PM.
#7 Wim Fournier
Wim Fournier
  • 177 posts
Posted 21 September 2015 - 03:35 PM
No, this is wurst. It is just ment for cleaning the air that goes into the crankcase because of the suction that you get with the crankcase ventilation tube connected to the carburettor foot. The system is called 'positive crankcase ventilation'. The word positive is indicating taht a smaal vacuum is applied to the crakcase.
