wow this is coming along nicely. Do love a mk2
Mk2 Cooper
#391
Posted 03 March 2019 - 11:32 AM
#392
Posted 03 March 2019 - 11:42 AM
Not much more visible done yet, but cleaned up the instruments, and wired up the switch panel, also fitted washer pump and tubing
Need to connect the binnacle, but want to fit the dash upper vinyl first.
6C7F920D-7DED-4857-B9D6-E002B395E3AE by darren carr, on Flickr
6EEC6D93-D8A1-4344-92D2-A2C005BB844C by darren carr, on Flickr
#393
Posted 09 March 2019 - 07:48 PM
Stuck down the arch covers and added some sound deadening pads
EE2BE63E-CAFA-4D53-A41F-CF46C4ABB07F by darren carr, on Flickr
F03D53BB-E803-4E5F-96DE-DE0EBAB03BBE by darren carr, on Flickr
670C6C6F-2541-4F29-B8BA-C2E23E740044 by darren carr, on Flickr
Not sure how much effect they will have but every little helps I hope, then I tackled a job I have been dreading to do, the dash vinyl, all went ok although a little awkward at times, also connected up the binnacle, want to fit headlining next but it needs a good clean.
5DCF08A8-917A-4999-BF96-4DCD466C04DE by darren carr, on Flickr
I then trial fitted the rear seat, after Giving it a good clean.
93A6DB61-82A2-4F96-9C58-244A6574CBB5 by darren carr, on Flickr
#394
Posted 13 March 2019 - 08:53 PM
Just a pic whilst it’s in the packaging to show the pile, glad I spent the extra compared to newton carpet.
B68A5DC5-60F7-45AD-98E9-EF418EFA03AA by darren carr, on Flickr
#395
Posted 16 March 2019 - 06:25 PM
Also fitted the newton rear cards, didn’t have much trouble with them but think they would be a bugger to get out without damaging them, hopefully don’t need to though. Cleaned my rear seat again, and also cleaned my headlining up ready to fit. Then ran out of time for today.
D560ABAA-049C-4345-9D30-C5A82314476B by darren carr, on Flickr
9C75324F-FB91-435A-B48C-38BD356949C5 by darren carr, on Flickr
#396
Posted 19 March 2019 - 08:03 AM
Where did you buy the carpets from? Are tehey that much better than Newton?
#397
Posted 19 March 2019 - 01:26 PM
I have used other items of newton trim and been happy with all,
#398
Posted 19 March 2019 - 05:55 PM
BAS international make them, they are a direct copy of the original veltone carpet used in late 60's mk1 and mk2 cars, The newton carpet is fine quality wise I have it in my mk1, just not correct if you want a car near to factory original spec.
Thanks, I guess the Newton set will be correct for my 78 GT. Always in the look out for recommendations.
J
#399
Posted 22 March 2019 - 02:41 PM
Have trial fitted the carpet, quality seems pretty good and not much trimming needed, the backing material has left bits all over it but will get a good vacumuming when fitted.
Daz
Is that hole correct for your gear change?
#400
Posted 24 March 2019 - 06:57 PM
My subframes also went for powder coating so feel like it’s getting somewhere now
7D335786-FAEB-4730-8E43-49268DC1EA3D by darren carr, on Flickr
A71944D2-DEDF-44E7-A6A0-E0724362EAF1 by darren carr, on Flickr
63C428EC-36FE-4374-ABBD-5DD577E797DF by darren carr, on Flickr
Edited by Daz1968, 24 March 2019 - 07:02 PM.
#401
Posted 24 March 2019 - 07:19 PM
#402
Posted 04 April 2019 - 09:43 PM
I managed to fit front to rear brake pipe, steering rack, column and steering wheel last weekend
F0228312-46AB-4C70-8662-7AC18697283A by darren carr, on Flickr
Then this week I got my subframes back from powder coating, so far only part I have entrusted to anyone else, I thought they turned out ok, had zinc coat prior to top black coat so hopefully will be long lasting, the one thread is a little short on rear mounting but luckily just long enough to engage in the nylon of the nut so will be ok, so I have a few bits to bolt on this weekend, luckily all parts are already refurbed so should be a quick process to get it looking like a complete car again.
AA07DF93-6FF0-4395-8122-1C2B14BAEF00 by darren carr, on Flickr
1EC7203C-945D-492D-8C1F-98EB34E310C1 by darren carr, on Flickr
So should have some more updates soon
#403
Posted 22 April 2019 - 12:33 PM
Luckily due to new full floor and boot being aligned using my frames they were easy to fit and literally fell into place.
I also used washers to space frame slightly during trail build to allow for the raptor coating.
2FD699E1-7804-477D-8516-8B2B6F203BCE by darren carr, on Flickr
106E108A-660B-4760-834B-ADF5D39A292A by darren carr, on Flickr
F74F29B6-EEE8-4D5B-A05F-ACC71D3CDF8A by darren carr, on Flickr
66D3AF36-FCC0-45C8-B366-1736177C3F6F by darren carr, on Flickr
Just need to sort out battery cable and fit front hubs and brakes, soon be on its own wheels.
#404
Posted 22 April 2019 - 03:44 PM
This is coming along really well.Fantastic job
#405
Posted 22 April 2019 - 06:03 PM
